It is currently Mon Oct 27, 2025 5:39 am
PostPosted: Wed Jul 03, 2013 3:36 pm
price lowered to $3000.
Please email ( sixspeedbass@gmail.com ) if interested. More pics avail upon request. No joyrides. Clean title in hand. Located in Tampa, FL.
In the end of 2009, I swapped in a JDM 4G63T from a Galant VR4 RS (Rally-spec homologation car), which I got from JHOT in Augusta, GA. The engine came from Mitsubishi with a big 16G turbo, 510cc injectors, a big FMIC, a close-ratio 5spd AWD tranny, and makes 240hp at the crank, in stock form. The engine has less than 40K on it, and doesn't leak or smoke at all. The car runs and drives great. Handles awesome. It's very light and very fast.
When I did the swap, I replaced the following: (all a year old and around 1,000mi on them)
Front and rear main seals
timing cover gasket
water pump
timing belt
timing belt pulleys
balance shaft belt
all acc belts
all vacuum lines
AWD tranny converted to FWD (by using a VCU eliminator...which can be removed if you wanted to return the tranny to AWD)
Upgraded to Ford injector clips (make swapping injectors WAY easier...no more annoying metal clip to lose)
New A/C compressor, new dryer, lots of new A/C seals/o-rings
Mods to the car include:
Brand new Miata battery in trunk
ACT 2600 clutch
2G MAF
3" turbo-back exhaust (no cat, one resonator....sounds awesome)
A'PEXi AFC
KYB AGX shocks up front, GR-2s in back
Tenzo R GF-2 springs (for 1G FWD DSM)
Yoshifab front adjustable camber plates
Autometer boost guage
Superpro front sway bar bushings
Prothane lower engine mounts (F and R)
Walbro 255lph fuel pump
20% Tint all around
ROH 15x7 wheels
Dunlop 225/50-15 tires
Galant VR4 RS shifter cables
Infiniti G20 front bumper
Sony MP3 CD head unit
Mitsubishi Expo front hubs with brand new wheel bearings
Galant VR4 2-piston front calipers with new pads and rotors
Adjustable FPR
EVO 1 Recaro front seats
Front and rear strut tower bars
Oil cooler
I'm sure I'm forgetting stuff.
What the car needs:
-Paint (it's flat black, which could use to be redone)
-There is a little bit of damage near the rear driver's side wheel, it needs to be worked over before paint)
-A tune (drives awesome and pulls hard, but it would be much better with a solid tune). Currently using the Galant VR4 RS ECU. I'm only running 10psi (oem wastegate setting). The turbo can easily run over 20psi with a good tune and proper fuel setup.
-Pass side mirror needs to be replaced (I will include one, not installed)
-Rear tires should be replaced soon
before oil cooler was installed in the driver's side fog light hole
older pic with honda-style radiator...has been replaces with original, full-length radiator with dual fans
crappy pic of the Recaro seats
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Mon Jul 08, 2013 10:22 pm
Scott,
Looks like a good amount of blood, sweat, and tears went into this project. Best Luck on sale.
If you have a moment to speak on the current suspension set up and method of G20 bumper mounting, it would be appreciated.
Kanpai!,
#89
PostPosted: Tue Jul 16, 2013 8:25 am
i also would like to know how you mounted the g20 bumper..i put one on my colt and the middle under the grill saggs even with the supports i made
PostPosted: Tue Jul 16, 2013 10:00 am
I have a 10mm bolt/nut at each outer corner (just like the OEM bumper cover). I think I had to drill a new hole in the fender for that (hard to remember, did it 4 years ago!).
I literally have two Harbor Freight spring clamps securing the upper lip of the bumper cover to the sheet metal. I believe I put them underneath the headlights (you can see in the pic that the bumper is most flush under the headlights). Hasn't budged in 4 years! Doesn't rattle or anything.
2018 Hyundai I30N
PostPosted: Tue Jul 16, 2013 10:59 am
I used a zip tie to tie it to the meta cross member you bolt below the headlights. It goes around its bracket. Stealth.
Thom
PostPosted: Tue Jul 16, 2013 11:23 am
GLWS!! I remember trailing you guys out to the highway when you came to pick it up!!!
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Fri Jul 26, 2013 10:26 pm
What year is the g20 bumper from? Did you have to mod it at all or just "make" some brackets? Thanks. It looks awesome.
Yawn....scribble.
PostPosted: Sun Aug 04, 2013 6:47 pm
The bumper was from the first gen G20s, can remember the exact years. Only had to trim the bumper around the intercooler, and popped out the foglight cups for IC piping clearance and to get airflow to the oil cooler.
2018 Hyundai I30N
PostPosted: Sun Aug 25, 2013 5:14 pm
Still have the car.
2018 Hyundai I30N
PostPosted: Sun Sep 22, 2013 12:47 am
2018 Hyundai I30N
PostPosted: Tue Sep 24, 2013 8:03 pm
Argh I want this car. Doubt you'll have it when I'm ready to buy though.
PostPosted: Tue Sep 24, 2013 9:08 pm
What are the side skirts from? Is it an original side skirt or something fitted? Thanks.
Yawn....scribble.
PostPosted: Tue Sep 24, 2013 10:30 pm
Those are original
PostPosted: Thu Sep 26, 2013 9:33 am
Yup, original turbo sideskirts. Please don't ask what I did with the original bumper/lip ](*,)
Still have the original seats though! And I'll throw them in with the car.
2018 Hyundai I30N
PostPosted: Mon Nov 11, 2013 4:11 pm
SOLD!
2018 Hyundai I30N
