It is currently Sun Oct 26, 2025 8:49 am
 Post subject: 4G61 block and crank
PostPosted: Fri Jun 28, 2013 12:03 pm
I had some bad luck on the dyno. The old 1.6 finally gave up. All the bearings had taken a beating from 7 years of abuse. The block is still the original stock bore. The crank will need to be turned .010/.010 to be cleaned up and run again. Not a big deal, but I am moving to a 2.0L finally after trying so long with this little motor.
$100 local or $100 plus what ever it is to send it to you. Last one I sold I put on a Greyhound bus for a reasonable price.
Steven Johnson
303-681-4575
1985 Mitsubishi Cordia
Build in progress
 Post subject: Re: 4G61 block and crank
PostPosted: Fri Jun 28, 2013 3:45 pm
This is a testament to these little 61t motors.
Good stuff - trucks bring it!
