| Trans, ECUs, Gaskets, T-cases, GM MAF/T http://www.4g61t.org/forum/viewtopic.php?f=66&t=37872 |
| Author: | dan [ Tue Jun 18, 2013 11:22 pm ] |
| Post subject: | Trans, ECUs, Gaskets, T-cases, GM MAF/T |
I’m moving on from DSMs for the most part. Make an offer; I’m more interested in moving it than making money. New oil drain tube (from FP), new manifold-turbo gasket, new exhaust manifold gasket, J-pipe all for $80 ![]() Updated, this is all that's left... |
| Author: | Keane [ Wed Jun 19, 2013 2:58 pm ] |
| Post subject: | Re: 14b, Injectors, Trans, Gaskets, T-cases |
Check inbox I pmed you on the injectors and water oil lines Thanks |
| Author: | #89 [ Fri Jun 21, 2013 11:39 pm ] |
| Post subject: | Re: 14b, OZ Wheels, Trans, Gaskets, T-cases |
Hi Dan, If you have a sec, price and center bore on the O.Z.s? Thx; Kanpai!, |
| Author: | dan [ Fri Jun 21, 2013 11:53 pm ] |
Quote: Hi Dan,
If you have a sec, price and center bore on the O.Z.s? Thx; Kanpai!, Looks like 67.1mm, $500 |
| Author: | xxNocturnalxx [ Sat Jun 22, 2013 12:50 am ] |
Those wheels are dope! |
| Author: | jdmhotness [ Sat Jun 22, 2013 11:52 am ] |
Dan, sent you a PM about the wheels! |
| Author: | dan [ Mon Oct 28, 2013 7:17 pm ] |
| Post subject: | Re: Trans, ECUs, Gaskets, T-cases, GM MAF/T |
Updated! |
