It is currently Wed Oct 22, 2025 10:43 pm
PostPosted: Sat Sep 01, 2012 8:11 am
All prices include shipping unless otherwise stated. All parts are in used, but good condition unless otherwise stated. I have been in DSMs for over 10 years and I'm not selling junk...unless otherwise stated. call/text with questions (33four) 6five7 - zero 8 1 5
All garage sale pictures are here: http://s132.photobucket.com/albums/q23/ ... e/31AUG12/
Cleaning out the garage. If you don't see it listed, ask I may have it. Performance parts listed first, then OEM/stock parts.
Garrett GT3076R One of the most popular of the Garrett Ballistic Concepts Turbochargers has been the GT3076R. It's rated at 52 lb/min, and comes with a T3 .63 A/R housing. It's a perfect street turbo, fast spool and will make 500HP. Perfect condition! Always used the FP inline oil filter and always turbo-timed. This is an absolute beast of a turbo especially at 25+ PSI. $600 shipped to your door.
Rebuilt MHI 20G Turbo Brand new internals. MHI, good quality build. $450 with a 7cm ebay turbine housing, $430 without. The ebay housing is actually a pretty good EVOIII 16g replica.
MHI EVOIII 16G Great shape. Little if any shaft play. Ready to use for years to come. $400 with 7cm ebay housing (same housing as listed above for the 20g. One of these turbos will have to sell without a turbine). $380 without turbine. TXT for pics.
Brian Crower Springs Great shape. Used with some miles, and ONE retainer has a nick on it, but won't affect performance. $100 shipped
2G MAS Adapter For 3" filter.
1G Head Excellent intake port matching. Questionable exhaust porting. Still worked well. Has good deck surface. Will come without valve springs unless wanted, just PM or text about the head. $125 shipped.
18 x 7.5 Kazera Rims Comes with Kumho tires in usable shape. has +30 or 35mm offset. Check the album for more pics and tread wear. $350 pickup only...or you pay shipping.
Knockoff Tial BOV Actually looks pretty good and I took it apart and the internals look good also. I never used it since I have a real Tial, but for what it is I'm sure it will work. Comes complete with weldable flange and everything. $Offer!
2G Intake Manifold Stock. Great shape. $Offer
1G ECU's Some EPROM, some Non-EPROM. Keep in mind the ECMlink guys can convert a non-EPROM ECUs to EPROM now. They can also convert a NT ECU to a turbo. Legitimate offers only, guys. I have about 6 ECUs in various trims. $Offers
Starion FMIC No damage other than some bent fins. Will work fine for a mild turbo setup. I also have aluminum pipe to be used as new inlets/outlets below $Offer
Aluminum 2.25" U-bend Perfect for using as new inlet/outlets on the Starion FMIC above, which was my original intention. Don't want it though. Looking for $30 shipped.
1G Throttle Bodies 91+ Good shape. No ISC unless we make a deal for it. $35 shipped each.
1G Exh. Man. Heat Shield Good shape. $25 shipped.
Misc 1G Brackets I have every bracket you can think of. $Offers
Misc Pulleys I have tons of pulleys, especially water pump pulleys. $Offers
Axles Good used. Most will need boots, but the axles can be re-booted or used as cores toward a reman at Napa or other place. $Offer - keep in mind shipping won't be dirt cheap because they are a little large/heavy.
Misc Mounts 1G. $Offers
Misc Electronics Some 2G coils mixed in with the 1G stuff. $Offers
Box-O-Crap See it? Want it? $Offers
90-91 Lenses I have the center lense and the passenger side and corner piece. Decent shape. $Offers
PostPosted: Sat Sep 08, 2012 8:46 pm
GT3076r
16G
20G
BC Springs
Knockoff TIAL
Sold!
PostPosted: Mon Sep 17, 2012 5:57 pm
hi there
Do you have the colt D/S shaft that goes from the hub to the shaft that bolts to the motor
Thanks
IRS awd evo3 rear floor colt check my build and tell me what you think
http://www.gsrcyborgclub.com/viewtopic. ... 952#p33952
PostPosted: Mon Sep 17, 2012 7:45 pm
I don't have any Colt parts unless it's the same as a DSM axle.
PostPosted: Mon Sep 17, 2012 9:57 pm
cool thanks
dont think they are the same.
PostPosted: Wed Oct 03, 2012 12:14 pm
Bump
Turbos sold. Anyone need 1G electronics, ECUs, axles or T-bodies? Selling pulleys and water pipes like hot cakes.
