http://www.4g61t.org/forum/
1991 Auto AWD Colt..
http://www.4g61t.org/forum/viewtopic.php?f=66&t=36545
Page 1 of 1
Author:  Red Sleeper [ Thu Jun 21, 2012 4:09 pm ]
Post subject:  1991 Auto AWD Colt..
As much as i dont want to do this.. I think i have to. Im in the process of buying and remodeling my first house, and could use the extra money from parting out my car.
1991 colt base model.
White exterior
GT interior
Crack free dash.
68k ORIGINAL miles.
Absolutly rust free..(turbo cluster)
Crack free bezel
AWD swapped... All the rear mounts are done. All the front engine mounts are done. Only thing it needs is the engine harness put in and driveshaft mounts. It will come with the following.
GT side skirts
GT door/fender moldings
JDM 3pc upper rear spoiler.
SS brake lines (new)
drilled/slotted rotors (new)
OEM 2 piston calipers and OEM rear (new)
New OEM rear subframe with poly bushings
Gvr4 front knuckles.
New wheel bearings all around.
extended studs on all 4
(20) brand new extended lug nuts'
Stock suspension.
engine mounts.
Wilwood Master cly. and pedal assembly. (new)
New AWD DSM proportion valve.
15" rota Slipstreams
1g auto shifter/cable
AS of now the car is still together, with engine/trans/fuel shits.. But can have it all off in a week for serious buyers.
With it the way its listed above.. $1800.
With the fuel set up. (2 walbro 255 inlines. 10gal tank. -6 to prefilters/pumps to a -8 Y to engine bay/filter. and -8 return.
($2400)
Will leave ksports on for another $500.
Im missing things im sure. But the car is SOLID! i spared no expense when puttng this thing together. All the Tubing for AWD is 1.75 and 1" DOM tubing. (seemless)
Thanks, pictures can be seen here:
http://www.4g61t.org/forum/viewtopic.php?f=57&t=35606
Author:  Red Sleeper [ Thu Jun 21, 2012 4:12 pm ]
Post subject:  Re: 1991 Auto AWD Colt..
The subframe in the car now has Active toe eliminator. Afco alum upper and lower control arms. Energy suspension swaybar bushings. and solid/poly front and rear bushings (mounts to car)
I can leave it in for an extra $400
Author:  turbotewes [ Thu Jun 21, 2012 6:51 pm ]
so all of this and no motor?
Author:  Red Sleeper [ Thu Jun 21, 2012 7:10 pm ]
Correct. Making it a roller.
Author:  dikdiamond [ Thu Jun 21, 2012 7:15 pm ]
AGH of all times to be broke,and moving in 3 months as well...DAMN IT!!!
Author:  slowdsm [ Thu Jun 21, 2012 7:20 pm ]
yeah if I win the lottery sat night ill buy it for sure lol..
Author:  Red Sleeper [ Fri Jun 22, 2012 6:10 am ]
Haha.. make it happen.
Author:  YFZracer32 [ Mon Jul 09, 2012 6:50 pm ]
Im still interested in that wilwood master setup if you decide you want to part with it...
https://www.phpbb.com/
