93 Laser 4 bolt / 6 Bolt http://www.4g61t.org/forum/viewtopic.php?f=66&t=36489 |
Author: | boostfreak [ Wed Jun 06, 2012 3:29 pm ] |
Post subject: | 93 Laser 4 bolt / 6 Bolt |
93 Laser RS AWD- 6 Bolt 4 bolt car. This is the lightest DSM AWD body you can find. Cleveland Clean underneath. Minimal surface rust-clear coat peel on the hood. You want to go fast for nothing? Here you go! Interior is 10 out of 10! Originally picked the car up the car to build it-knew it had a motor issue-found a bent rod. At this point, if I put it back together-its going to be with mostly stock parts and WILL sell for 2k since it s running driving 6 bolt 4 bolt car. I’d rather sell at a loss to save time for other projects! Mods-3inch exhaust, 255LPH. Trans shifted great before the motor issue-stock clutch-car was bone stock until 2010. Take it as a rolling shell with Rear/Driveshaft/T case for $600. I will toss in the minty trans for $800. I will toss in a good running 6 Bolt for $1200. I will get pics up if there is interest-if not I will toss it together when I get some free time. Pics ] ![]() ![]() ![]() Paint peel on the bumper from the Le Bra on the car. ![]() ![]() Non rustyness ![]() ![]() MINT interior |
Author: | boostfreak [ Tue Jun 12, 2012 9:33 am ] |
Post subject: | Re: 93 Laser 4 bolt / 6 Bolt |
Pending- will consider trades as well! |
