It is currently Wed Oct 22, 2025 3:41 am
PostPosted: Thu Jun 09, 2011 10:45 am
Apartment life does not have it's perks when it comes to extra vehicles. Looking to see if there is a competent user here, whether they be in Canada (easiest) or the US (paperwork involved in border crossing the car permanently), to sell the car to.
Asking 5000k <- Realistically, no need to call me on this as this is my asking price, I've spent over 2.5/3k just in the past year and more than likely over 4k in the past two years. Car was acquired for 2.5K originally. Bumper from France alone cost me pennies shy of 1K with all the extra parts, landed to the airport here in town.
PLEASE SEND REASONABLE OFFER REQUESTS VIA PM, I WILL GET BACK TO YOU SHORTLY.
The goods:
1989 Plymouth Colt C53A acquired 2004/5 near 182,000 km's and now sits somewhere up near 195/6k?
One owner car before I got it. Lived in Ontario it's whole life. Heavily rust proofed by first owner, reason the undercarriage is so great looking and still coated.
PO and his family were/are members here still I believe. I've kept the car in good hands so far, and would ideally see it changes to another set of good hands. I have 120-130 of these cars catalogued in the VIN REGISTRY that I run, out of the roughly 1500 cars that saw North American shoes in 1989.
Passed Ontario Emissions standards summer 2010 - tested as Hod Rod due to 2.0l block installed.
This car can be passed for another Ontario Emission test if buyer is living in Ontario in a driveclean zone, anyone else outside of these zones will not require a Drive Clean Emission pass/certificate. Consumers in BC, Ontario and maybe a few other places in Canada have the emissions tests, so if you are responsible for a test in that province when the car were to arrive, I cannot guarantee that the car will pass at idle the way it is setup right now, as the idle circuit has trouble keeping up with the regrind cams and lopey idle. Once the idle is brought up off the IAC circuit control point, it passes with flying colors. :D The car meets the 1980 Modified Block status for the Ontario emissions program, and I can get it through another test for you without hassle if you are registering in TO, or Ottawa, or any area that has Emission test requirements in Ontario, the ministry just needs the paperwork in hand for the ownership transfer. I live two minutes from the local Ministry of Transportation office, so if you are purchasing the car for use in Ontario all the better and easier. I can also guarantee that this car will pass a Safety inspection, as I can provide that as well. The hole in the engine bay sheet metal will need to be patched to conform to minimum standard though, just so people are aware of that.
Spare parts:
Original 4g61t motor - complete, no factory turbo or manifold, in pieces and crank already polished and flywheel machined.
ARP headstuds for 6 bolt
Full set of engine/transmission mounts just pulled from the car Spring 2011 - recommend Window weld as my drivetrain jerked at low speeds due to weak rubber in the mounts, reason I installed the Urethane mounts at all 4 corners for the engine and transmission Spring 2011
New head gasket from Hyundai for a 4g61
Original KM210 transmission - 2/3 syncros grind at high rpm gear shifts, no issues and clean fluid always run through it
Full set of axles left and right, 1 stock, 1 aftermarket - 1 needs boot
4g63t cylinder head with stock valve train - came from motor that was in last car the new motor is in
450cc injectors, 2x fuel rails DSM, injector seals
3G lifters - less than 2k on them
AWD starter
Tons of stock air piping for intercooler and turbo setups - 1 full VR4 setup in there too
EVO 8 exhaust valves ground and ready to install
Stock 4g63t intake valve - back cut and polished
Turbo cluster - 240 KMH and 9K RPM - has Australian internals but does read MPH on face
HKS 264/272 Intake and Exhaust camshafts - fresh out of an 8K US motor down at RRE
Walbro 255 LPH pump w/sock - sitting since pulled from a setup run for just 30 minutes
JDM dual runner intake manifold - painted VHT super wrinkle coat black with red lettering, spare wiring and all vacuum accessories
Rear brake rotor dust shields from Australia - rust free and OEM black
Spare seat covers full set for front, no rear, torn and somewhat dirty but perfect for tear repair etc
JDM reconditioned silver wheels in rough shape cosmetically - 6.5/15" with Mitsu center caps, has 205 55 15 Herc's require replacement
Aeromotive AFPR A1000 - need on adapter to fit rubber line to stock return, comes with fluid filled gauge
DSM FWD H&R drop springs 1.6" front and rear (rears installed on car right now)
Uncracked matching color dash pad cover - came over from France
GTi/JDM Euro from bumper cover - Dark Green possibly Belize Green like the GVR4's, now with matching front bumper brackets, has headlamp sprayers and pump, from France (thank you Coltixim!!!!!!)
Rust free Fuel Pump Sender assembly for a C53a/C52a CSM and a spare DSM Eagle Talon 91 AWD fuel pump as well (thank you 89Mirageman!!!!!)
Full set of FSM's manuals - Greens, Blacks, Reds for 89 Colt turbo, non turbo, Vista, etc 89-91/92
Backup sheet of what is chipped on the 90 Eprom
GVR4 press release booklet with brochures, microfiche <- lol, and black and white photos of a demo car
Installed as of now:
1G 6 bolt 4g63t Japanese crate motor - all emissions installed and functional, running Mobil 1 5w30 Full Synthetic changed every 2k or less
NEW OEM dipstick
264 regrind camshafts by SP (some local Ontarian that ground up some cams a few years back) with shimmed lifters
14b turbocharger installed
Ported 02 housing
Rewired fuel pump - fuse in engine bay
2.5" exhaust system / Ractive single SS polished tip at rear - needs new rear muffler, new owner gets to choose what the car will sound like
NEW 2.5" Magnaflow Car Sound catalytic converter - New spring 2010
M&S Recycling (Jon Reimer) customer FMIC - Starion core, short route, piping matches 2G TB elbow
Keydiver setup 90 Eprom running tons of internal mods - Stage 3 essentially with more options in it
2G MAS
Prothane/Urethane engine and transmission mounts installed. Installed spring 2011
Yoshi FAB front upper strut mount bar - installed Fall 2010
4 corner KYB silver struts - none leaking, rear newer, spare set of KYB rear struts, not leaking)
B&G lowering front springs for Colt/Summit 1.5" drop (H&R FWD TEL drop springs in rear, matching (to the fronts) BG rears waiting installation)
KM210 from colt turbo out of the US - running 50/50 Syncromesh and 75-80/90 diff fluids
NEW DSM FWD ACT 2100 New design clutch with pressure plate 225 mm up from 215 mm stock - installed fall 2010
NEW Fidanza light weight aluminum flywheel with 7gte bolts to crank 8.2 lbs as listed on site - installed fall 2010
NEW OEM clutch slave and master cylinders, SS braided clutch line - installed fall 2010
Australian Grey/White face gauge cluster - original odometer transferred over - NO MPH MARKINGS!!!!
Custom gauge cluster - PVC, Fibreglass and bondo painted roll cage black - mounts on steering wheel top cover
5 Defi Racer Blue gauges EGT, ECT, BOOST, VOLT, OIL PRESSURE - all gauges wired and operational - need to install EGT bung
NEW Battery relocated to trunk in Taylor Stainless vented box (properly vented outside the vehicle) mounted with 1" square tubing and threaded rod to frame - 2-4 AWG wiring installed - no voltage sag !!!!
NEW larger High CCA battery in trunk, will also include 1 smaller battery but proper sized and matched unit for this car - Eliminator from Canadian tire
Pioneer CD 45x4 head unit driving amps in trunk Via RCA output
3 amps in trunk - 1 10" sub
NEW 195 65 14" tires on factory Vette style rims with center caps
NEW GVR4 Mitsu OEM front brake hoses, rear brake hoses white box in a box - installed brake Front brake hoses Fall 2010, rears have yet to be installed
NEW/USED Factory front calipers and brackets to replace the old calipers with seizing top slider pins - installed spring 2011, Full brake service spring 2011.
NEW inner steering rack tie rods - sent from Australia - hope these fit, were for this application according to sender
Sunroof conversion -appears similar to other units installed in US by dealers - resealed by me at one point
NEW ACC carpetting - dark grey so not dark silver as original - enough spare material to make floor mats to match, or almost another floor pan
Restitched front seats and washed covers - fishing line repair and foam repair on side lower bolsters
Door cards do not have speaker cut outs but they are in the door itself - junk yard replacements, matching color
Shifter boot now has new cover, with red sections of leather - black red combination, old unit in box
Kid seat tether bolt added at center tailgate location - easily removable but a great tie down piece
Cruise control system in full duplicate and 2 ECU's to match, system will not engage, so bought alot to fix it with but never diagnosed it - could be a simple repair but I covered all the bases - not the vacuum hose setup like a DSM
Custom timing gear holding tool from, "91talonharv", just arrived spring 2010
Bosch factory plug in alarm unit of some sort - cannot find any reference to it on the internet. Never had a problem with it, but this means it is old I assume.
Best parts of the car:
Great pickup with the 14b, both down low and highway
Chipped for 91 but run 94 Sunoco octane 90% of the time
Flushed all brake fluids Spring 2011
Never left me stranded to this point.
Dash pad has 1 tiny crack in it - uncracked spare from France to go with car, matching color
Looks good, sits low, sounds mean, lots of undercoating on the carriage and other spots - saved all spots other than those listed from surface rust
The things I would consider TLC to get the car 100 %:
Wide Band 02 sensor and control unit
90 Eprom with no damage to circuit board - this one was resurrected years ago now by Jeff
Inner tie rod ends -supplied
Muffler finally has lots of holes in it - sounds good though ..... still quiet but recommend changing it out as the weld to the inlet/outet are corroding loose and they are what holds the muffler up, won't fall off any time soon though
Rust at wiper arm hole on tailgate, rear wheel wells, front fenders (new units at $150 per side is a good deal), RF strut tower to side fender frame area - spot that will require a good patch and thankfully won't look out of place once welded in
It would appear the PO tried to take the rear struts out without getting the rear axle far enough down - dings on inside of LR fender require a little painless dent repair
1 "Daewoo Leganza green" mirror housing - saved from an original GT out of the southern US states - needs to be sanded and painted silver to match
Leak at front windshield under heavier rains when parked uphill - reason I tore out the carpet and rust prepped the floor - suspect small hole
Dent on front hood pictured, appears that PO had someones ass planted there - not rusted, just looks humourous
Just about every bolt has been removed, cleaned, replaced or otherwise cared from while the car was down for pretty much 2 overhauls.
Brake system such as rotors, pads, bearings all changed 2006 except rear bearings.
Folder with every single receipt, emission test, etc, for everything that has been worked for this car. All work performed by myself. I built this car to be safe and comfortable and it is.
Members thread here for more:
http://www.4g61t.org/forum/viewtopic.php?f=9&t=12968
More pictures here too:
http://www.4g61t.org/gallery/v/members/Flying+Eagle/ GALLERY IS DOWN AS OF OCTOBER 2011 WILL COME ONLINE AS SOON AS IT CROSSES OVER
More pictures to seriously interested buyers or as time allows.
Car and all parts will go in one shot deal.
I will still have a car to drive and keep my little one safe with, but I am seriously considering the acquisition of a 4x4 VW/Bombardier Iltis. I was taught to drive standard on these little cars/trucks, and have the itch to get one now that I have zero urge to ever be a part of the military again. :lol: I feel it is only fair to ask a good price for my car because of all that it has in it, and the extras that will also come with it. When and if I move into getting an Iltis, I want a turn key affair and do not want to be modding it like I had to with the Colt. The Colt is a finished project from my perspective, but that is only because I have lost interest in the body restoration, for the spots listed above. I am now a licensed Automotive Technician and need to put my efforts to better use for my son, as I have been doing since I became a single father. Hoping the car finds a good home with an enthusiast, time will tell with the applications received.
CASH preferred, willing to work with US buyers to help to get them the paperwork they need, but most of it will be the paperwork needed to cross back onto the American side with the car (buyers responsibility to find this out), and it's spare parts. Car is insured and driving as of today, just need to get a bolt up into the 02 housing to exhaust downpipe flange, last part of the rebuild for this season on the road. Figures an M12 x 1.25 is hard to find! I may just run a smaller bolt and lock washer combination though, with a new solid metal gasket from RTMRacing.
That is everything I can think of that relates to the car, I am sure there is more, and there is probably a bunch more parts that are ready to send with the new owner too. Not a sad day, just cannot park and pay for two spare cars. 8) Besides the new owner will have enough spare parts to build another turbo swapped car, or sell off to members who could really use them for their cars, and possible restorations.
PostPosted: Thu Jun 09, 2011 10:48 am
More pictures to follow. Out of town this week, back weekend of June 11/12. Have access to the site during that time.
PostPosted: Thu Jun 09, 2011 5:45 pm
wow, sorry to hear you have to sell the car but goodluck Tim
My feedback thread:
PostPosted: Tue Aug 16, 2011 8:10 am
PM'd
PostPosted: Tue Aug 16, 2011 6:39 pm
Owner/Admin
PM'd
Also add that address in your user control panel, so we know where Tims car is going. If you buy that car :oops:
PostPosted: Tue Aug 16, 2011 9:56 pm
PM'd
...so we know where Tims car is going.
If I did, it would go beside my VR4 :)
PostPosted: Tue Aug 16, 2011 10:43 pm
Tim-a-ty...say it ain't so.
PostPosted: Wed Aug 17, 2011 9:20 pm
Yeah, Ian if you add your city/province/country that would be great because it is one of those base rules for all of us.
After that we're easy to get along with I promise.
Yes, car is up for sale but for all the right reasons. I have built it and now run it. I have enjoyed it for a long time but don't have the proper space to keep it out of the elements and to
finish the body work the way it should be to keep it alive for a long time to come. Pics are down until the gallery is up and running, but I have just finished swapping in the matching B&G Colt specific drops springs in the rear and it now sits flat. There is a little clunking now, so what changed I am not sure till it gets up on the hoist again. Times are busy and I would rather focus on my personal life for me and my son. We both enjoy the car and it now has the AC working so we both enjoy it that much more! It would be sad to see it go, but think of how much space I would have at work (bumper in a box), home (motor and pieces in plastic crates), and my brother's family's place (shed and garage) once I get rid of all the spare wheels, parts and so on and so forth. I want to get my life back to where it should be for how I want to live as a Trades Person right now. Work at work, no work at home. 8)
