It is currently Tue Oct 21, 2025 1:01 am
PostPosted: Fri Jul 08, 2011 10:29 am
I have a white 2 door 1991 Plymouth Colt 4 speed 1.5l with 91k miles that needs some love. I bought it a few months ago and it has just sat in the driveway. I just don't have the time it needs to make it right. It's manual everything, no a/c. The motor runs great and the miles are accurate. It will need a transmission, tires, brakes, and struts. Also the gas tank is leaking if you fill it. Alternator has been replaced as some point. Cooling system works awesome. Front windshield is cracked and it has some rust but the underbody is solid. As far as I can tell it's never been in an accident. Interior is complete minus the plastic around the column but the ignition and key work so I'm not sure why it's missing. None of the locks turn but I do have one original key with the code on it and the owners manual. It has a clean title that's in the process of transferring over so I can mail it to the new owner. I think it would be a good car to fix up or just use it for parts. I just hope someone on here can do something with it. If you have any questions let me know and I will answer asap. I have pictures but I'm not sure how to post so if someone can help me out that would be awesome. Car is located in Holland MI. Transmission is finally done, here is the clist link.
http://holland.craigslist.org/cto/2492426781.html
