It is currently Tue Oct 21, 2025 1:01 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Sun May 15, 2011 11:40 pm
Hey guys. I recently stepped up to a slightly larger turbo and a FP cast manifold, so I'm selling my old setup. This 2g manifold has been ported pretty much as much as you can possibly port one of these things. It was on my car when it dynoed 482whp. I've ran upwards of 30psi on this wastegate setup with no flow issues whatsoever. All this stuff is very old, and not in amazing condition, but it all still works fine. We put the wastegate off the collector instead of off the #1 runner because you get significantly better flow from all 4 cylinders instead of just one, hence the welded-shut passage on the #1 runner. I'm looking to get $150 shipped/paypal'd for everything you see here, 2g manifold and TiAL 35mm wastegate. You're on your own for a dumptube. Also, this was installed on a DSM its whole life, so I can't say for sure if it will bolt on to a CSM, but it fit great on a DSM even with 2 fans and everything, no clearance issues.
PostPosted: Fri May 20, 2011 12:04 pm
BUMP, still for sale
PostPosted: Fri May 20, 2011 1:53 pm
PM sent d00d.
PostPosted: Fri May 20, 2011 1:57 pm
PM replied, br00
PostPosted: Fri May 20, 2011 2:05 pm
Gimme dat PayPal!
PostPosted: Fri May 20, 2011 2:25 pm
Pending payment from mister shaun man.
PostPosted: Sun Jun 12, 2011 7:49 pm
sold?
89 Factory Turbo Mirage 4g63T Hahn MHI 20g @20psi
2004 subaru baja turbo 5spd...almost an STI.
PostPosted: Mon Jun 13, 2011 12:09 am
Yep, sold.
