It is currently Mon Oct 20, 2025 2:19 pm
PostPosted: Thu Apr 07, 2011 11:21 pm
*** EDIT: I forgot to mention this car has Galant VR4 front brakes w/ 2 piston calipers, correct geometry and custom made camber plates! ****
I'm posting this for a good friend, and I can personally vouch for the quality of this vehicle. Available for local pickup in Sacramento or delivery to Texas. Send inquiries to: hauling_assvr4@hotmail.com
**** Please see his VERY DETAILED original post on galantvr4.org: http://www.galantvr4.org/ubbthreads/sho ... Post982110
It is a 1991 Dodge Colt GL 1.5 liter 12 valve Automatic.
Manual steering, door locks and windows.
122,795 miles on the original engine.
Head gasket and wheel bearings just replaced.
It is rolling on a set of OZ Racing 15x-" +--offset rims from a 20-- Mitsubishi Lancer OZ edition (I will get the rim dimensions later) with matching 195/50-15 Bridgestone Potenza S-03 tires on them.
Other Goodies that could go with it if the owner is interested are almost everything needed for the manual swap.
The shifter assembly, the clutch pedal assembly, the clutch hard line and rubber line and the slave cylinder.
What is needed to complete the manual swap is the shifter cables, transmission, clutch and flywheel and the manual ECU. I may end up sourcing the rest of the parts soon anyway (I will have everything except the transmission).
Also, I can include a 1G DSM Turbo FWD trasmission, bad left and rights AWD DSM axels good for cores, a 6 bolt 4G63 block and head that need to be rebult and a turbo 4G63 ECU and harness along with all the other misc. engine parts from that same '93 Talon TSi AWD I parted out.
PostPosted: Mon Apr 11, 2011 6:05 pm
Bump. Forgot to put that it has Galant VR4 brakes up front, with correct geometry and custom camber plates. No interest? I'd expect a few lowballers at least by now!
