It is currently Mon Oct 20, 2025 2:19 pm
PostPosted: Sat Mar 05, 2011 10:00 pm
Prices shown do not include shipping or paypal fees.
Elantra non cruise throttle cable-direct fit for the na csm guys doing a 4G63 swap $15
Elantra coil with tach adapter Sold
Elantra upper t-stat housing Sold
Elantra throttle body-same as 91-94 na DSM TB $35
Elantra t-belt mount $25
Elantra electric trunk solenoid with oem button (would be great to mod to fit a csm to have a push button hatch/trunk release Sold
Elantra black valve cover with all studs, washers and cap nuts. No cracks or stripped threads, spark plug cover also included Sold
3g CSM hatch window trim L & R, Sold
3g CSM auto tach cluster 127K, Sold
3g CSM manual tranny shift levers and cable bracket Sold
3g CSM corner lights Sold
3g CSM amber bumper light MINT Sold
3g CSM Colt filler panel $35
3g CSM P/S mirror manual $12
3g CSM headlights- one of the tits :oops: broken but otherwise perfect, the other one has a tiny crack on the gray plastic $10 each or $18 for both
2g DSM 609 maf, honeycombs still in tact, with oem connector Sold
1g DSM 4G37 1.8L maf, ECU, injectors and T/B Sold
1g DSM na 2.0 DOHC injectors $20
Intrepid coils with oem plugs $15 for 4 coils, please specify diagonal or straight across mounting holes
PostPosted: Sun Mar 06, 2011 12:09 am
I want the tach cluster for my NA car. PM me shipped cost :D
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Mar 06, 2011 9:36 am
cluster, bumper lights, trunk solenoid & door trim sold.
PostPosted: Tue Mar 08, 2011 12:33 am
Give it a week or two and I will take the Elantra Throttle Cable off of you, It's bolt on for the 1.5 swapped car so i wouln't have to modify? Never heard of using those, WANT! :P
PostPosted: Tue Mar 08, 2011 12:21 pm
To be honest I haven't tried it but they should be identical. I will compare it to my throttle cable in my car and make sure it fits before its sold.
PostPosted: Thu Mar 17, 2011 8:41 am
Most everything sold but there are a few things left. Coils reduced to $15 for 4 so that I can move them. Come on guys for $15 you can wire up your own COP setup.
PostPosted: Fri Mar 25, 2011 6:38 pm
bump
