It is currently Mon Oct 20, 2025 2:34 am
PostPosted: Wed Nov 10, 2010 10:23 pm
Selling my 90 Mitsubishi mirage
Car is non running but is a great start for someone that wants to swap a 4g61/63 into it.It still has the 1.5
I was driving to work and it just died out and didnt start again. The stock 1.5l transmission doesnt have 4th gear Havnt had any time to diagnose the problem but seems like distributor went out since it still cranks and has compression. The ecu was rebuilt from when I bought it. One door handle is broken on the drivers side outer door. I have tried finding one but cannot seem to find one anywhere. It already has the hydraulic clutch in it so no cable clutch.
Body has 250xxx miles but the cluster now reads less since it was swapped out for a different one.
The car has:
Galant vr4 front and rear seats installed.
Galant vr4 wheels painted black
Cluster with a tach
Single bulb amber corner lights
Stock turbo dsm fuel pump
Will be included:
Original turbo engine wire harness
Original turbo mounts with poly's
91 fwd turbo trans
Original turbo axles
90 ECU
To get running it would need:
Motor
Flywheel
Asking 1100
720-317-5017 if no answer send text or leave voicemail
Link to craigslist ad for pic....http://denver.craigslist.org/cto/2052101429.html
PostPosted: Wed Nov 10, 2010 11:34 pm
Wish you weren't so far! Bump for a nice swap sedan
