Hey everyone, i have a bunch of excess parts for a 6bolt that need to go. They are all functional unless specified otherwise. Here goes:
Greddy knockoff BOV with 1g flanged pipe $25
1g stock big rod/piston combo (pistons have light wear and need a cleaning) $125
ARP rod studs for 1g big rods BNIB $30
J-pipe for a 14b/16g to route a FMIC $20
Stock 1g oil drain line $10
1g clutch line lightly used $5
1g oil cooler w/ banjo bolts (slight damage from the way i had it mounted, doesn't affect performance) $20
Magnaflow 2.5" in/out catalytic converter (less than 1k miles) $75
1g multilayer exhaust mani gasket (lightly used) $10
1g side mount intercooler $30
2- 14b o2 housings $10 each
1g big rods (pistons are no good) $40 for all 4
1g intake manifold $40
6bolt auto crank (can be used for manual if u remove pilot bearing) $50 SOLD
6bolt block w/ main caps and oil squirters (my old block-never saw more than 22psi) $125 SOLD
4 stock steelies for a csm(lots of tread left) $15 a tire
SHIPPING IS NOT INCLUDED
Thanks for looking!
