It is currently Sun Oct 19, 2025 11:59 pm
PostPosted: Sat Aug 07, 2010 3:47 pm
I have the following stock 98GSX parts available free for pickup only. I will NOT ship!
Front suspension components (both sides):
upper and lower control arms. Bushings/joints look ok
strut/spring assemblies w/ upper & lower mounts
brake calipers w/ brackets (work fine)
aftermarket drilled/slotted rotors (usable, probably need to be turned)
Other:
Stock shifter assy
Stock FW with ~500mi after resurface. Usable as is.
Rear suspension components available as soon as I get the new stuff installed. Most of this stuff is going in the trash if nobody picks it up. Calipers will be sold and shipped if there is no local interest. Also have new hawk pads for the front and a greddy UICP with some crappy BOV on it that someone can have cheap if they pick up the other parts.
I'm in Santa Barbara and can meet up with someone almost anytime.
