Had a custom set made for my car Fits 89-94 colts/mirage
set is about $2000 and Im letting this go for $1500. They are still NEW in box
You can also adjust the bottom part of strut and the spring as well meaning you can leave the spring set at whatever rate and then adjust the bottom part of shock to go as low/high as you like
SELEX COILOVER
- Spring Rates: 10kg Front and 8kg
- Fully 16point Adjustable
- Pillow Ball Upper Mounts w/ Front Camber Adjustment
- Wide-Range Adjustable Ride Height
PM me or email
rick@garage16.ca
thanks
