The link to GalantVR4 site for the original post, the pictures are much larger in this forum...
http://www.galantvr4.org/ubbthreads/sho ... =0&fpart=1
Brand New...100% Aluminum, hand welded, constructed with a bar and plate design.
Good for up to 600bhp. all our intercooler has been tested to withstand more then 80 psi pressure and it has very small pressure drop across the end tanks,
at 15psi inlet the out let has 14.8psi that means it has only 0.2 psi pressure drop ,compare to many other intercoolers it is an excellent figure
(some intercooler has 1-2psi pressure drop) also at the same condition, the temperature has drop from 120 degree to 28 degree
( and it is an excellent figure for efficiency)
Core Length :18.5"
Core Height:6"
Core Thickness:3.5"
Inlet Size:2.5"
Outlet Size:2.5"
Overall size(with endtank): 20"x12"x3.5"
$70.00 plus shipping or best reasonable offer
This side mount intercooler I purchased from 89Mirageman and Chris had this modified for a Colt/Mirage install
$35.00 plus shipping
This monster I got from Rob aka TeamDuckTape many years for a build that never happened.
It has a 10.5' x 9" x 4.5" core, 3.5" OD input and output piping and 3/4" NPT water hookup for cooling.
$75.00 plus shipping
