hi i have 1 91+ eprom ecu. case part number: MD166262-E2T36578E and the inside white connector number: 6578E
a little bit cloudy on parts of board and tiny spots of corrosion on the white card thing near the caps, but was working fine in my car.
THIS ONE IS SOLD
1 91+ non eprom. ecu case number: MD166262-E2T36578M and the inside white connector number: 6578M
super clean board and i bought with caps replaced, someone wrote burnt isc chip on back but i have no details on that. this ecu also worked fine in my car.
i looked up both of these in one of the various dsm ecu identifiers and they both show up to be 90-92 tubo awd manual trans ecus. one eprom and one not
both ecus only have one screw holding the cap on sorry
$125 shipped for the eprom ecu
THIS ONE IS SOLD
$75 shipped for the non eprom ecu
I have gone to megasquirt and no longer have a need for these ecus. i havent used them for a while so as a measure of good faith since these have been sitting for over a year in my basement and i want someone to get good parts. Just in case the caps went bad im offering a 30 day warranty in this way. If the ecu doesnt seem to work and you send it to ecm tuning within 30 days and you can show they had to fix it. i'll send you $30 back. (that is there rate to replace caps but shipping would still be on you) thanks
