It is currently Mon Oct 20, 2025 2:12 pm
PostPosted: Tue Apr 12, 2011 8:47 pm
Negative Nancy
This is new and sells for 130 new, and 60 used. Will sell for 80.00 new shipped. The photo is a stock one but will post an actual if needed. Need gone this week. Looks just like the pic.
•Tumble polished billet look
•New lower housing casting for enhanced fuel flow
•Motor draws only 3 amps current
•7 1/2 amp fuse recommended
•Improved design for street/strip applications
•Distinctive “BLUE” logo
•Flows 110 GPH (free flow)
•Flows 88 GPH at 9 PSI
•Maximum pressure is 14 PSI
•Provides constant fuel flow with no pulsation
(max 14 PSI)
•Rotor/Vane pump design is more tolerant of contaminated fuels
•Weighs only 3 lbs
•Includes mounting bracket
•Repair kits are readily available
•Can be serviced from the pump end
•NOT compatible with alcohol or methanol fuels
•Use of safety shut-off switch, P/N 12-810, strongly recommended
•Not designed or recommended for use with fuel injection systems
