It is currently Sun Oct 19, 2025 5:10 pm
PostPosted: Thu Jul 01, 2010 11:50 pm
This is an aftermarket replacement stock manifold for a 1g 4G63T, and a galvanized custom upper heat shield. The manifold is in good condition, and is ported to match my EVOIII 16G that was ported by FP. It has no cracks, but the threads are a little jacked in the front lower heat shield mounting point but it works well with a long enough bolt.
I took it off because I got a FP race manifold. :D
$50 takes the whole package.
EDIT: Excuse my crappy memory, it turns out all the bolt holes are perfect after all.
PostPosted: Tue Jul 13, 2010 10:12 pm
I want to buy thsi manifold but i am not to pay heat shield. I am from Bulgaria. How much will is cost manifold + shipping to Bulgaria.
PostPosted: Tue Jul 13, 2010 10:56 pm
I think I could ship it "large priority mail flat rate" for $56 as long as it will fit a 12"x12"x5.5" box, and not exeed 20lbs.
That would bring your total to $91.00 for just the manifold, so if you really want it that bad I can check the dimensions/weight tommorow.
