It is currently Tue Jun 04, 2024 7:04 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
PostPosted: Sat May 03, 2014 11:51 am
Well I've been sitting on this one for a few years now. Its starting to get a little closer so I figure I'll share. Its not quite the normal... but I figure it will make some of you think :)
As some of you know I bought this truck a few years back thinking "It's a v6, I won't cram a 4g in it!". Well my mind started wandering and the parts came along and got the best of me...
I always had a thing for GMC Syclones, maybe because my first truck was a 91 Sonoma. However I just couldn't make myself buy one. So here I am, building my own Mitsubishi varient... Maybe I should codename it Tsunami...
Bought this totaled 3000gt VR4
So they both came with a 6G72, the car one is DOHC, but the lower blocks are pretty much the same. There was a raised portion on the car block I had to notch off to clear one of the motor mounts, other than that, it all bolted up.
The car engine the thermostat on the back of the heads, so I used a 94ish montero 3.5 liter water pump and thermostat housing to move them to the front, as well as some custom fabrication on the rear cross over and return pipe, and the water pipes for the heater core. I'm using a 2005 Galant 3.8 upper intake, bolter to the stock 3000gt lower intake.
I used an upgraded clutch pressure plate for a Starion, and a sprung 6 puck disc for the truck from Clutchnet.com
https://scontent-ord.xx.fbcdn.net/hphot ... e=55860EB7[/img]
This is it sitting in the truck, before I moved it over to my new place.
I'm using the 3000gt accesories, and rerouting the lines for the AC and power steering, they are on opposite sides from stock now, but the lines are actually shorter this way. I'm also went single turbo (tdo6 20g), easier fab than the stock twins, and I think it would be way easier to deal with. The twins could be made to fit, but it would be very tight. The CAS will not clear the firewall, so instead of cutting it, I have 2 choices, first is swap to a 93+ front case, and head to use the separate sensors that the used on the newer ones, as well as swap the ecu. Or as I'm having done, we are making it work from the front of the head.
So go ahead and call me crazy :)
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat May 03, 2014 4:23 pm
Is that a socket on that CAS?
PostPosted: Sat May 03, 2014 4:37 pm
Yup. Had to move it to the front for clearance issues. I'm gonna make it work :)
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun May 04, 2014 2:01 am
Which trans are you using for this? Also, what clutch/flywheel combo?
PostPosted: Sun May 04, 2014 6:06 am
Crazy project for sure, suscribed :D
PostPosted: Sun May 04, 2014 6:16 am
V6 mighty max trans, 4x4. Starion pressure plate, truck disc.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun May 04, 2014 9:02 am
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun May 04, 2014 11:44 am
Awesome.
If the cas originally went on the back would it not rotate counter clockwise? Are you going to modify the optical plate?
PostPosted: Sun May 04, 2014 11:55 am
The optical disc has been flipped, should fix that problem.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun May 04, 2014 9:55 pm
Love it! Cant wait to see it finished.
PostPosted: Tue May 06, 2014 1:57 am
Now that's a project!
PostPosted: Tue May 06, 2014 9:15 am
I'm jealous. I want you to finish this and bring it to shootout!
92 GS sedan, 100mph burnouts = sold
PostPosted: Tue May 06, 2014 10:03 am
I'm trying, but I really don't want to rush it. Things never go well in a rush.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 07, 2014 9:12 pm
Wow. Awesome. Different.
PostPosted: Sun May 11, 2014 10:41 am
Little update on the intake!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
