It is currently Tue Oct 21, 2025 4:17 pm
 Post subject: New 50 trim install
PostPosted: Sat Mar 05, 2011 10:34 pm
Forced Performance had a sale at Christmas time so I picked up these goodies:
FP cast manifold + 255 walbro= 50 trim hta green
 Post subject: Re: New 50 trim install
PostPosted: Sun Mar 06, 2011 12:06 am
That's a pretty sick setup.
PostPosted: Sun Mar 06, 2011 12:27 am
Had a problem with the where the compressor housing was pointed=my motor mount:
so solved that by redrilling the solonoid position on the housing so it could be clocked, plus cutting 1/2" each off housing and elbow:
PostPosted: Sun Mar 06, 2011 12:33 am
FP recommended oiling come off filter housing instead of the cyl head so we did this:
Is this where its usually fed from?
PostPosted: Sun Mar 06, 2011 2:58 am
Shouldn't your elbow face the drivers side?
PostPosted: Sun Mar 06, 2011 4:32 am
Because Race Car
Looks like it is to me.
PostPosted: Sun Mar 06, 2011 12:03 pm
Is that a ball bearing or journal bearing turbo? If it is a journal bearing you will most definitely need a restrictor in the oil feed line if the CHRA doesn't have one in the oil inlet.
PostPosted: Sun Mar 06, 2011 1:22 pm
It is a journal bearing , but isn't the reason the oil line is run off the FH because there is too much pressure in the head?
PostPosted: Sun Mar 06, 2011 1:23 pm
My intercooler is same side inlet/outlet.
PostPosted: Sun Mar 06, 2011 1:38 pm
There is much more pressure off the FH than off the head. Even feeding off the head you should still use a restrictor will a journal bearing turbo. Just look in the inlet, I bet it already is restricted like a 16g.
PostPosted: Sun Mar 06, 2011 3:12 pm
k, I'll check it out.
PostPosted: Sun Mar 06, 2011 4:40 pm
Because Race Car
Doh! I was thinking about the oil feed fitting :oops:
PostPosted: Tue Mar 08, 2011 8:13 pm
Ball bearing turbos need an oil restrictor. Journal bearing turbos usually don't. And as already stated, the oil filter housing has higher oil pressure than the head.
Is that Green going on a 1.6 or 2.0? BTW, if you have issues with the gasket that goes between the exhaust manifold and the turbine housing (like I did), you can just not use one (like I did). Just use copper or nickel antiseize on the bolt threads and torque them to the high end of the spec.
Dave Peter
-1994 Eagle Summit LX Wagon FWD, Manual Swap
-1989 Mirage Turbo
-1990 Plymouth Colt Vista Wagon AWD
-1992 Galant VR-4 (sold)
Can't polish a turd.
PostPosted: Tue Mar 08, 2011 10:28 pm
Fp says to feed from the oil filter housing, on certain turbos.
PostPosted: Wed Mar 09, 2011 7:19 am
A journal bearing turbo will push oil past the seals if the oil pressure is too high.
