91 Eagle Summit AWD http://www.4g61t.org/forum/viewtopic.php?f=64&t=34304 |
Page 4 of 18 |
Author: | antilag_200 [ Sun Nov 27, 2011 1:01 pm ] |
Post subject: | Re: 91 Eagle Summit AWD |
I am trying to understand why adam did that, but it isn't a big deal. I am sure he will chime in . I have a set of those lower arms that are cut up but nothing that is stock unfortunately. actually I took a quick peek of your thread. Your car is coming along as well |
Author: | KOTScolt [ Mon Nov 28, 2011 9:44 am ] |
Car looks HOT! Looks like its ready for some rally action. I would change were the earls ff attaches to the tank with that hard 90deg, i've seen those fittings break more then once. I'd run a short piece of ss or rubber so its not directly bolt to the tank. |
Author: | antilag_200 [ Mon Dec 05, 2011 8:10 am ] |
did some more welding on the interior, mostly patching up some holes that were left behind. here is the interior with the first layer of primer Also I was able to mock up the location for the seats, tacked and welded all of those points in as well. and a full shot |
Author: | antilag_200 [ Tue Dec 13, 2011 8:30 am ] |
nice and red next up dropping the entire rear subframe |
Author: | CSM Shaun [ Tue Dec 13, 2011 11:40 am ] |
Very red. |
Author: | Red Sleeper [ Tue Dec 13, 2011 2:55 pm ] |
almost need sunglasses to look at those pictures. |
Author: | antilag_200 [ Mon Apr 16, 2012 8:12 am ] |
Loads of updates on the car Full interior has been installed Wiring harness has been converted to incorporate a flashable 2g ecu HKS 272 cams with greddy cam gears are installed. Engine bay harness and chassis harness has been completed on the front of the car the fuel system is going to be worked on next where the second 255, ID1000 cc injectors and regulator are to be added stay tuned also thank you "cheaptalon" for my turbo colt bumper |
Author: | Red Sleeper [ Mon Apr 16, 2012 9:10 am ] |
Looka good. Your like 2 steps ahead of my pile. Interior is going in this week along with fuel setup. Hah |
Author: | antilag_200 [ Mon Apr 16, 2012 9:44 am ] |
I have still not tackled that rear end suspension issue, however I did cut out the towers that were there before. Your project looks awesome , I took a quick peek at it . Unfortunately for me I have a lot of energy being diverted to my other pile of crap evo and I m building this for my son, which consequently leaves very little time left over for the summit. evo set up ( Just converted the car to Ethanol, running 40 ish psi, and speed density with stock ecu) it is a 4 linked articulating suspension radio flyer |
Author: | Red Sleeper [ Mon Apr 16, 2012 10:29 am ] |
Noo shit. I'm about to start on a wagon for my daughter haha that's funny |
Author: | antilag_200 [ Mon Apr 16, 2012 10:33 am ] |
Yeah man its alot of fun to build it, the wagon has magnesium wheels, billet 3 bolt hubs for the rear on floating bearings etc etc... here is the project log for my Son and I radio flyer .... damn it I am tread jacking my own thread !! http://www.xceedspeed.com/forums/showth ... 199&page=1 you will like it man, lots of tech and fabrication that I have done to it |
Author: | cheaptalon [ Mon Apr 16, 2012 4:07 pm ] |
I gotta check on that read bumper still. You have something i need to borrow anyhow. Good progress! |
Author: | antilag_200 [ Tue Apr 17, 2012 6:25 am ] |
Ben , we do need that rear bumper, what stuff are you looking for, shoot me a text or pm on xceed |
Author: | antilag_200 [ Tue May 29, 2012 10:34 am ] |
Small update over the weekend. wired up rear lights and ignition. still need to run starter wire to solenoid and constant 12v for ecu along with dash. Finished the fuel hardline. Just need to build the bracket for the fuel pumps. showing the hard fuel line to the fuel filter set up showing new stance from the side and rear ( wagon is bonus material) |
Page 4 of 18 | All times are UTC-05:00 |
