It is currently Thu Oct 23, 2025 12:42 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page 1 2 3 Next
PostPosted: Sun Mar 06, 2011 12:51 am
Here she is in all her current miserable glory. In the weeks to come I will be doing a ecu swap with tons of rewiring to get my 1g ecmlink stuff to work with the car. Also I'm in the process of locating a 2g awd stuff for the awd conversion, I basically need every thing!
PostPosted: Sun Mar 06, 2011 1:02 am
Wow Ive never heard of this! Sounds like you will be one only a few?
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Sun Mar 06, 2011 1:19 am
Didn't these come awd with the turbo v6, across the pond? Those are pretty cool. What rear end you going to use? Also aren't these in the same configuration, as the 4-9 evo's, where the t belt is on the pasager side.
PostPosted: Sun Mar 06, 2011 1:30 am
Yeah its pretty rare to see these swapped to awd, but you would not believe how easy it is. You have to make to small cuts into the body from above the trunk to access the upper nuts holding the rear into place and pull all that junk out. Then you basically just bolt the 2g stuff in, it's really a peice of cake. Even the 2g gas tank can be used if you weld in new tabs for the tank. The hardest part of the install is going to be making a carrier bearing bracket. And the elec is also if not the biggest issue, these cars use a 2g style wiring harness and are obd 1. They even use the 95-96 2g style cas. Its weird the car has both obd1 and obd2 diagnostic plugs!
whe3ls > Yea these were offered as VR4's with a v6 twin turbo, and I'm on the look out for a complete 2g lsd rear (manual) and subframe. The motor in it is a 7 bolt 4g64 with everything being almost exactly the same dimensionally as a 4g63 etc. Also the 2g suspension peices are all nearly identical too.
not mine but for reference.
PostPosted: Sun Mar 06, 2011 1:55 am
Nice project! This is actually one of those rare Mitsubishi's that I haven't had the chance to own yet. Although I did find one in the junkyard a few years ago and stripped some of its parts. Keep us updated and take plenty of pics.
PostPosted: Sun Mar 06, 2011 4:30 am
Because Race Car
This is a first for this site :o I'll be following this one for sure.
What is the weight on this to start out? I'm going to guess slightly more than a 2G AWD.
PostPosted: Sun Mar 06, 2011 4:40 am
Thats sweet! I love seeing new 4g63t swaps.
PostPosted: Sun Mar 06, 2011 11:59 am
Just chop a carrier bearing mount out of a 2g and weld that into place. No fabrication required. Will you have to make or modify a driveshaft? I expect that it is longer than a 2g but it could be awefully close.
PostPosted: Sun Mar 06, 2011 1:57 pm
The weight is around 2755 lbs. the way it sits.
Yea the option of reusing the center carrier bearing off the 2g is the way to go, but I'm goin to fab up something for the rear mount. The driveshaft doesnt need to be modified either, crazy huh. Seems like this car was meant to be AWD! :partyman:
PostPosted: Sun Mar 06, 2011 2:05 pm
Does the suspension look like a 2G? They could be like Avengers and use all 2G FWD bits. Wouldn't surprise me.
PostPosted: Sun Mar 06, 2011 2:12 pm
Your exactly right, same as 2g fwd in the front. They are also identical to the avengers and close to the 2g fwd in the rear with the shock being a little shorter making the difference.
PostPosted: Sun Mar 06, 2011 2:14 pm
Super cool man. Makin your own GVR4.
PostPosted: Sun Mar 06, 2011 6:14 pm
My Friend Mitch has one he's staying fwd though.
Check out The Galant center, I used to be active there it's a pretty cool forum. ( Had an 8th gen)
Here is his 7g
http://www.youtube.com/watch?v=V6HPPivhe7s
That was the initial start up, he has a tuning and dyno date on April 8th
PostPosted: Sun Mar 06, 2011 6:29 pm
this is awesome, keep it up
My feedback thread:
PostPosted: Mon Mar 07, 2011 10:25 am
Wow I really like this! I would love to copy this idea for a DD someday.
