| Swap number 3 underway http://www.4g61t.org/forum/viewtopic.php?f=64&t=32600 |
Page 1 of 2 |
| Author: | aaronsbig16g [ Mon May 03, 2010 11:24 pm ] |
| Post subject: | Re: Swap number 3 underway |
Love the teal colts! Cant wait to see this thing together. |
| Author: | fastvtgsx [ Tue May 04, 2010 8:31 am ] |
Quote: Love the teal colts! Cant wait to see this thing together.
I actually like the teal color too, unfortunately my fiance isn't much of a fan and has asked a couple times if I'll paint it for her. You shouldn't have to wait too long for this to be done, I have all the parts I need. |
| Author: | DarkHorse [ Tue May 04, 2010 12:51 pm ] |
what axles and tranny are you using. love the teal, too ~joe |
| Author: | fastvtgsx [ Tue May 04, 2010 1:59 pm ] |
Quote: what axles and tranny are you using.
Turbo mirage outer axles and dsm intermediate shaft with 1g fwd tranny. I'll be running a ACT 2100 w/ clutchnet organic unsprung with a fidanza flywheel.
| Author: | fastvtgsx [ Thu May 06, 2010 2:03 pm ] |
![]() She will be on the road and driving today. |
| Author: | Evotistical [ Thu May 06, 2010 2:57 pm ] |
wow I think that might be the quickest swap ever |
| Author: | Evotistical [ Fri May 07, 2010 4:23 pm ] |
what mounts did you use? |
| Author: | fastvtgsx [ Fri May 07, 2010 4:56 pm ] |
Added to the post above. Just a little note, your car won't start without the intake manifold ground. Ask me how I know... |
| Author: | 89Mirageman [ Fri May 07, 2010 7:39 pm ] |
Well, I feel like crap. Mine has been down since November and I still don't have a tranny, the entire front suspension is still off and I have to put the t-belt on What do you mean the intermediate shaft won't bolt on with the fwd tranny? You have to have the AC bracket bolted on because it spaces out the bracket on the shaft. I usually just cut the lower corner off of the AC bracket if I'm not putting the AC back on to save a pound or two. You also have to take a new fwd tranny seal and clean it up, then use rtv to glue an awd seal to it. Sounds kinda ghetto but I promise it works perfect. Edit: This is with a dsm intermediate shaft also. I think the csm turbo ones snap right in and work with the fwd seal. |
| Author: | fastvtgsx [ Sat May 08, 2010 1:02 am ] |
Quote: Well, I feel like crap. Mine has been down since November and I still don't have a tranny, the entire front suspension is still off and I have to put the t-belt on
Haha, you shouldn't feel like crap, your build is way cleaner and detailed then mine. Plus, it helps that I can work on it all day. What do you mean the intermediate shaft won't bolt on with the fwd tranny? You have to have the AC bracket bolted on because it spaces out the bracket on the shaft. I usually just cut the lower corner off of the AC bracket if I'm not putting the AC back on to save a pound or two. You also have to take a new fwd tranny seal and clean it up, then use rtv to glue an awd seal to it. Sounds kinda ghetto but I promise it works perfect. Edit: This is with a dsm intermediate shaft also. I think the csm turbo ones snap right in and work with the fwd seal. I really don't know why but I can't get the dsm intermediate shaft to work with a fwd tranny. I'm using the a/c bracket and the holes just won't align. Took her up to the track tonight with some friends to see how she'd go. Best time was 15.3 @ 89 mph, this was on 7 psi (b16g), no intercooler and stock catback exhaust on 175 winters. Plenty of room for improvement, I'm happy with the results so far. |
| Author: | 89Mirageman [ Sat May 08, 2010 8:15 am ] |
Are you sure the intermediate shaft is from a 5 speed car? I know there are slight differences between the two. If it is from a manual car for sure jack the front of the car up and take one hand and rotate the tire while pushing in on the intermediate shaft. Then again if the axle you are using is working fine I would probably just leave it. If its a na axle though it probably didn't seat correctly and it could fly out of the diff. |
| Author: | fastvtgsx [ Sat May 08, 2010 11:47 am ] |
Ya, it's a manual shaft I'm pretty sure I got it from you. I guess I could bore out the bolt holes a little but I tried everything to make it fit, just would work. For now the stock axle is working fine. |
| Page 1 of 2 | All times are UTC-05:00 |
