Well guys the time has come to get rid of the sedan. I'm more of a hatch guy and my buddy Aaron is willing to do almost anything to get his car back. Him and I are planning to trade my sedan for his 89 hatch sometime towards the end of the month. We were planning to take care of it Saturday but due to some unforseen circumstances that never happened.
Anyway guys I sat down tonight and came up with some ideas as to what I want to accomplish with the hatch that he's giving me. I'm planning to have a comfortable and reliable daily driver that I can occasionally take to the track and wring out. Something to have fun in and is still easy to drive on the street and take long distances if it's required. This car will not see a turbo because I don't want a rediculously fast car like my 92 hatch was and I had more problems with it as a turbo car. Plus I need that reliability because for the first time in 12 years this will be my only car.
But I want you guys to give me an idea of what you think of this setup because I have ALWAYS wanted to have a naturally aspirated engine in my hatch that when I stomp on the throttle will not hesitate to lay down some torque and create lots of smoke and black marks. I know I can count on my boy Tony to give me some blunt opinions on what he thinks and that's the kind of tough love I need right now
OK, here's what I'm thinking...
4G64 6 bolt block
4G63 6 bolt head with 92 turbo cams
Cometic MLS head gasket (mostly to help lower compression)
NT Intake Manifold
80mm throttle body
Chinabay header
F5M33 5 speed trans
Hydraulic clutch swap
2.5" exhaust with Magnaflow muffler
240cc injectors
Colt GT axles
Elantra Motor Mounts
High Flow Fuel Rail w/AFPR
Walbro 190 w/rewire or 255LPH fuel pump
ACT 2100 clutch kit
Fidanza lightweight flywheel
91-94 NT ECU
NT Engine Harness
89Mirageman's adapter harness
1G MAS
K&N filter
Colt turbo gauge cluster
Of course there will be a new full gasket set and water pump installed. I will be keeping the balance shafts and all new belts and tensioners will be installed before the engine is put in the car. I would REALLY REALLY like to install a power steering rack and pump. I'd also like to install AC later on down the road. This will obviously not happen overnight because all the people here that know me know that I like to take my time and I'm strapped like two lesbians at a cock fight. Hopefully this won't be a long and drawn out process like my 92 hatch was but I'd like to hit it hard and get it done right the first time. I need some insight here guys as to what you think I should change in my list because I'm still learning as to what block/head combos work here. I know the 63 head installs on the 64 block but what I don't know is what the outcome of the static compression ratio would be which is I mentioned that I will be using a MLS head gasket because I'm imagining that it would be in the area of 13:1 or so and without methanol injection it's not going to last long. But anyway guys thanks for reading my novel here and thanks for your insight in advance. You all are awesome.
PS, here are some pics that I got from Aaron...
And finally a picture of his new girlfriend...he said it's getting pretty serious and he was thinking of proposing to her. Good luck buddy! We're all happy for you two!
The only thing that sucks about their arrangement is the fact that he has to wrestle her away from her ex. Aaron shot this pic when he was taking the car to get checked out.
