New Build, 1994 Mirage Coupe AWD http://www.4g61t.org/forum/viewtopic.php?f=64&t=32965 |
Page 3 of 3 |
Author: | TrevTec [ Fri Dec 31, 2010 9:33 am ] |
Post subject: | Re: New Build, 1994 Mirage Coupe AWD |
Finally finished the head. Got the GSC S3 Cams with GSC Beehive springs and retainers, fresh valves job with 1mm over size valves. I also got a Kiggley Flex plate and HLA Pressure Ragulator. |
Author: | whe3ls [ Sat Jan 01, 2011 10:40 pm ] |
that looks sick |
Author: | TrevTec [ Tue Jan 04, 2011 6:52 pm ] |
Did a little more work. Got the interior almost done and finished putting the head together. |
Author: | CaptainTonus [ Tue Jan 04, 2011 7:12 pm ] |
Looks legit. |
Author: | whe3ls [ Tue Jan 04, 2011 10:14 pm ] |
sick... |
Author: | Flying Eagle [ Thu Jan 06, 2011 9:04 am ] |
Quote: Quote: I think the evo 1-3 rear subframe goes in pretty easy on the 4g cars from what I've read.
I couldnt tell what has been done besides cutting out the spare tire hump which I think was only done for the cell. Looks like they drilled a few holes and bolted it all in. They had a complete donor car when they did it. Almost all the parts from this car are from the RWD AMS EVO 1.http://www.pixcl.com/summitgtx/lancerproject_2.htm http://www.pixcl.com/summitgtx/lancerproject_3.htm |
Author: | TrevTec [ Thu Jan 06, 2011 11:29 am ] |
Quote: Quote: Quote: I think the evo 1-3 rear subframe goes in pretty easy on the 4g cars from what I've read.
I couldnt tell what has been done besides cutting out the spare tire hump which I think was only done for the cell. Looks like they drilled a few holes and bolted it all in. They had a complete donor car when they did it. Almost all the parts from this car are from the RWD AMS EVO 1.http://www.pixcl.com/summitgtx/lancerproject_2.htm http://www.pixcl.com/summitgtx/lancerproject_3.htm Im gonna remove the rear end on mine and I will take a bunch of pics of what was done. The drive shaft looks goofy, its all crooked down the middle of the car. |
Author: | 89D15CRX [ Thu Jan 06, 2011 1:11 pm ] |
Trev man this thing is awesome. I don't know any other word to describe it. I've been watching this since you first posted it and I can't wait to see what this thing can do. Keep up the good work bro! I can't believe you have as much time as you do to work on your own cars after working on everyone else's at the shop all day. Now THAT'S dedication. |
Author: | TrevTec [ Thu Jan 06, 2011 10:46 pm ] |
Helps when you hire monkeys to do all the hard work for you. |
Page 3 of 3 | All times are UTC-05:00 |
