It is currently Thu Oct 23, 2025 2:15 am
Post new topic  Reply to topic  [ 345 posts ]  Go to page Previous 118 19 20 21 22 23 Next
PostPosted: Sun May 08, 2011 3:16 am
CSM O.G.
Chris you have to hold back now. I know you want to rotisserie the whole chassis. Tsk tsk, for shame! :twisted:
in the relatively-lightweight mk1 vw world, the OCD ones build a "tiptissorie", flip it on one side, work on it, put it down and reverse them, then flip it on the other side.
heres a quick google result:
http://www.mk1dubz.com/forums/showthread.php?t=534
PostPosted: Mon May 09, 2011 10:35 am
That Tip-tissorie is awesome!
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Tue May 10, 2011 8:55 pm
I got a little more done on the colt today. My brother brought over his Hobart plasma cutter and let me borrow it to cut the spare tire area out. This thing was a life saver for sure, no sparks flying everywhere like there would be with a cutoff wheel. Now I just have a few more spot welds to drill out to clean up the frame rails a little.
First I laid underneath the car and drilled holes every 6 inches or so out-lining what I wanted to cut out. This allowed me to just connect the dots in the hatch with a sharpie so that I would have something to go by when dragging the torch.
The damage.
PostPosted: Tue May 10, 2011 9:11 pm
Looks awesome Chris, I've always wanted to try using a plasma cutter. What with the recent work it seems like you're finally past the point of no return :lol:
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Tue May 10, 2011 10:01 pm
Lookin good, plasma makes for a nice even cut. I've been tryn to get a hold of plasma to cut into mine at the moment. Have you figured out what your goin to use to cover it back up? I really like Coltsfan swap where he replaced the rear pan with the 1g stuff, it made for a suttle and stock look and is what I'm goin to try and duplicate.
PostPosted: Wed May 11, 2011 8:25 am
Yeah, no turning back now. :P
This particular plasma cutter sells for about $750 new at Tractor Supply. It runs on 110 household current and has a tiny onboard air compressor so no need for a separate one. 1/8" is about the max that it will cut but its still very useful for projects like this. It does cut a very straight line if you can pull the torch straight, as you can see I didn't do that. I could have clamped down something to guide it but I figured I'd just even it out with a flap disc on my grinder later.
I have no idea what I'm going to cover it with once I'm done. I agree, Dayo did a nice job of making his look like it came that way. I need to decide if I'm going with some type of regular tank or flat fuel cell underneath. That will determine what I do about the trunk pan. It would be nice to have somewhere for a spare tire.
PostPosted: Mon May 16, 2011 6:47 pm
Still crawling along on this thing. I got a few more spot welds drilled out today so the frame rails are clean and ready.
I also finished removing the rear of the floor pan down where the tow hook was. I forgot to grab a pic but here are all of the misc pieces that came out today.
While laying on my back drilling spot welds I saw something that I didn't like. Looks like my colt is finally getting the rust on the roof from the glue they used to hold it to the braces. So now I get to remove those and clean it all up to keep it from getting any worse. :-?
PostPosted: Thu May 19, 2011 5:59 pm
I dug most of the parts for my awd rear subframe out of the barn and put it all together. I will be tearing it all back down and blasting/painting each part once I fab up the mounts. The 16X8 3000GT wheels barely clear and it doesn't look like they're going to stick out too far. I think it will look mean once its all together and lowered with some short 16" tires, 225/40's maybe.
I finally got my engine hoist over here so that should make it a lot easier to raise and lower the rear subframe. Looks like I can just raise the hatch and lift it through there but we'll see.
PostPosted: Thu May 19, 2011 6:33 pm
Is the slab of concrete new?
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu May 19, 2011 6:45 pm
Well I see someone hasn't been reading my updates. :lol:
Yeah man, its been done for about 5 weeks now. Look back on page 17 if you want to watch it dry. :P
PostPosted: Thu May 19, 2011 6:55 pm
It's a good thing you got the rust free fuel pump assembly out of there, it just would have been in your way the whole time. 8)
PostPosted: Thu May 19, 2011 9:02 pm
Hey I'm subscribed, so I do get email updates!!!
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri May 20, 2011 9:03 am
Easiest four-lug swap ever! LOL
PostPosted: Fri May 20, 2011 10:03 am
Hahahaha, minutes after that I was down to only two. A few were not in there straight so the rotor wouldn't go on there. I wanted to slap the wheel on so I knocked them out with the hammer. :lol:
PostPosted: Sat May 21, 2011 2:46 am
I always look forward to updates on this project! Can't wait to see the rear end bolted up.
