Progress on my AWD swap (long time comming) REAR END IS IN http://www.4g61t.org/forum/viewtopic.php?f=64&t=12825 |
Page 12 of 12 |
Author: | fastvtgsx [ Tue Jul 20, 2010 11:16 am ] |
Post subject: | Re: Progress on my AWD swap (long time comming) REAR END IS IN |
Looks good, I'm with Trev on this one though, I don't think you needed to move the bottom mounting point that much if you already modified the top, esp if your running the coilovers I see in the background. |
Author: | adamrx7 [ Wed Jul 21, 2010 9:02 am ] |
Quote: So these struts were also 8 inches shorter than stock?
Quote: Looks good, I'm with Trev on this one though, I don't think you needed to move the bottom mounting point that much if you already modified the top, esp if your running the coilovers I see in the background.
Yeah I had the new Struts on the car and the wheels bottomed out in the wheel wells. This was what I had to do to make them work. I dont think both of these mods will be needed to be done by everyone maybe just one of them. But this is what I had to do. The new Struts were all the way extened also. This will give me the adjustment I need. |
Author: | Coltsfan [ Wed Jul 21, 2010 9:43 am ] |
Holy bejesus batman! Where do the calipers go? |
Author: | Coltsfan [ Thu Jul 22, 2010 7:12 am ] |
Quote: Are you using that brake for speed control or dyno help? or both Ive heard about this in the rock crawling community, but never in racing.
That's just a random picture I googled; I thought it might help give inspiration. As for the applications, I've seen these used on drag cars. Mostly dragsters with huge slicks, or show cars like a tubbed out Wyllis coupe or something.I personally would replace the trailing arms. |
Author: | adamrx7 [ Sat Jul 24, 2010 6:40 am ] |
I have mocked up the caliper and all I have to do is "notch" the new strut mount and it should work. |
Author: | fastvtgsx [ Sat Jul 24, 2010 11:06 am ] |
That's good you're able to make it work still! Although you probably could have gotten away with some big front brakes, sense most of the braking comes from the front anyway. |
Author: | adamrx7 [ Thu Sep 09, 2010 7:09 pm ] |
So I've been lookiong at what I did and I think I'm going back to the way it was. |
Author: | adamrx7 [ Sun Oct 24, 2010 10:36 am ] |
Alright I picked up a new rear end for the car and putting the strut mounts back to original DSA specs. |
Author: | adamrx7 [ Thu Nov 18, 2010 12:10 am ] |
Here we go, new parts all around. Rotors and calipers are on. So are the rear axles. |
Author: | adamrx7 [ Fri Jan 28, 2011 5:15 pm ] |
Update : The driveshaft has been installed !!! I had two days off work and decided the Summit was what I wanted to work on. The install went good pictures to come. |
Author: | Flying Eagle [ Fri Jan 28, 2011 10:33 pm ] |
Yay for motivation! |
Author: | adamrx7 [ Sun Jan 30, 2011 7:52 pm ] |
Here are the rear mounts - they came out great- Nice and strong Dive shaft needs to be shifted a little but I designed the mount so I could do that. |
Author: | adamrx7 [ Fri Feb 18, 2011 11:57 pm ] |
I have sold the car and will pas the legacy on to Warren. I'm closing this page this week and will let him start a new one. I will keep all the pictures and info up thos to help every one. It was a blast to work on and hope she will come alive soon. |
Page 12 of 12 | All times are UTC-05:00 |
