Had another one follow me home, now fun cruiser project! http://www.4g61t.org/forum/viewtopic.php?f=64&t=40424 |
Page 2 of 2 |
Author: | fastvtgsx [ Tue Nov 24, 2015 12:18 pm ] |
Post subject: | Re: Had another one follow me home... |
I got some tunes installed recently. Bought a JVC unit that will charge your phone through the usb port so I don't really need to mess with adding a 12v source. Found out after installing it, this thing came with no audio at all from the factory. The stock front dash speaker locations were bare! So I stole the 4" speakers I had in my mirage and we have sound. I'll add some speakers to the back eventually. Also managed to retrofit a 2g shift boot onto the stock colt shifter. While I was in there, I pulled the shifter assembly apart and replaced (wasn't even there anymore) one of the bushings so it feels a good amount better now. I need to find time to hit some salvage yards but really doubt I'll find anything with as old as these things are now. All the parts are still waiting to go on, I've found myself busier than usual and the mirage is taking longer to get finished (nothing new). Still not sure what the plan is for this thing, I'd love to be able to find an a/c setup to put in it and throw the 4g63 I have sitting around in it for my wife to drive. She's always saying she misses her old hatch, who knows how she'd really feel about driving one again. lol |
Author: | fastvtgsx [ Thu Nov 26, 2015 7:23 pm ] |
I was able to get the brakes swapped over the other day. I did it the slide hammer way and it worked well. Bearings looked to be in good shape so I put new grease on them and slapped it back together. The sedan rotors are the same diameter, but vented and thicker obviously. The pads are a generous amount larger. I compared the calipers to single piston DSM calipers and they are dementionally the same so good cheap upgrade. I also found the reason why the front end shakes while braking. The right inner tie rod is shot, nice clunk back and forth. The ball joints looked and felt good though. I ordered new inner and outer tie rods from Rock Auto and will just replace all of them at once and be done with it for good. Slowly but surely she will make it back to her golden age and better hopefully! |
Author: | fastvtgsx [ Thu Dec 17, 2015 6:19 pm ] |
I got the passenger side tie rod ends swapped out and back together. Still getting a clunk so I will swap the driver side ends out next and then swap the struts and get it re-aligned. The door handle has been installed, but unfortunately the lock cylinder is messed up. I might look into swapping the passenger and driver cylinders that way at least I won't have to go to the passenger side, unlock on the outside, reach across, unlock and then walk around. As soon as I can find the a/c stuff for this car, I'll look into stuffing a 4g63 inside. But I want to do it all at once if I do it. |
Author: | fastvtgsx [ Thu Jan 21, 2016 6:29 pm ] |
All the tie rod ends have been replaced now. Driver's side wasn't horrible but I'm hoping that will be the end of the front end clunking. Alignment can finally be done now and I'll be able to take it out and about. |
Author: | Mechacode [ Sat Feb 20, 2016 3:17 pm ] |
I did 253 at the wheels with a 14b and stock 450cc injectors at 18lbs. Should be pretty easy for you to hit that number. I STILL can't get over how shiny that thing turned out! |
Author: | Flying Eagle [ Tue Feb 23, 2016 3:56 pm ] |
Great information about the mirrors crossing over! Different part numbers must have been differences between complete assemblies that get shipped with those bezels in differing shapes to suit. |
Author: | fastvtgsx [ Thu Mar 17, 2016 3:16 pm ] |
Post subject: | Re: Had another one follow me home, now fun cruiser project! |
It is getting close to go time on this swap. I am on vacation next week and am looking to have a running, driving, cold a/c car by the end of it. I've cleared the garage out, cut up the parts car and took it to recycling. I ordered and received some BG lowering springs from THMotorsports.com. This was the first time I've ordered from them and I was impressed. Great price, $192 shipped and quick communication. I was a little worried when they said the springs weren't in stock, but the were able to get them drop shipped from BG with 2 day shipping. There was no way I was going to be able to stick with the stock suspension. Body roll is horrible and there is no agility to speak of. So I've begun prepping the suspension and putting the new stuff together. I also ordered a Comp Clutch flywheel sense FWD flywheels seem to be impossible to find used. This will be the first flywheel I've used from them, I've always had aluminium. That came in today. The transmission got new axle seals and new Sachs TOB and got cleaned up a little. I've never used a Sachs TOB but I foresee any issues with it, it looks well made. I'll be using a ACT 2600 with street disc setup on the Comp Clutch flywheel. The motor will be put on the stand real quick to make the waiter pump and timing belt change easy. I'm not going to do anything with the internals. After that's done, I'll bolt everything together and get it ready to go in. I'll make sure to post some pictures along the way. Someone might as well move this over to the builds section. |
Author: | Flying Eagle [ Fri Apr 22, 2016 5:27 pm ] |
Open up your lowering springs, and pull them out of the box. Compare them to your current spring setup, do this right away. There were many issues a short while back where guys were getting springs but they weren't exactly what they were supposed to be. Trying to look out for you, on this one! |
Page 2 of 2 | All times are UTC-05:00 |
