You guys keep bringing that elevation issue when you post dynos, but the Dynos are just giving you a little extra, if not more than they should.
Is that will stock cams?
I noticed he posted his uncorrected numbers...not his corrected and the dyno he was at was closer to 6,000 ft. It sounds like your saying a turbo completely eliminates elevation issues, I do agree that corrected figures are obviously inflated, but the real sorry is the power under the curve. What a dyno does show is that through a peak efficiency range of about 1,000 to 1,500 rpms, a turbo car will perform close to its performance at low elevation. Before and after that small window, the cars suffer from noticable powerloss.
I'm also not sure about a 1.6L making more hp than a 2.0L at any elevation with similar mods. But Jason was absolutly correct about a volumetric efficiency range for a turbo. What I've noticed is that my 1.6 will spool a turbo about 1,000 rpms later than a 2.0 and as a result, peak hp is usually 1,000ish rpm later. I have literally spent hours calculating VE tables for my motor and cams. I even calculated out gearing and what rpm each gear change would net with my transmission and tire size. If anyone wants to spend few ours reading and is comfortable with a lot of trigonometry then I will gladly link you to sites that can walk you through it with great detail.
Like Davis also mentioned, I don't use local dyno's anymore unless I want to inflate my ego. I prefer to use a more consisten equation based on trap speed and total race weight. It doesn't matter what elevation your at, the numbers still crunch out the same if your speed and weight are similar. My car works out to 403 whp using these equations, which sounds a little high but I don't doubt I was in the area of 380 whp uncorrected. The last time I was on the dyno was two years ago, I was using an afc2 to tune with and only had 550 cc injectors on pump gas along with a whole bunch of loose ends. The injectors were maxed out at 23 psi and my uncorrected numbers were 308 whp and 223 ft/lbs. Just to give another example, when I enter my weight at the time and trap speed (2300 lbs/ 118.9 mph) it calculates my whp to be 301.7. It has been freakisly accurate for me over the last 5 years on several different turbo setup's.
