It is currently Wed May 22, 2024 11:29 pm
PostPosted: Fri Apr 08, 2016 1:25 pm
Somebody was trying to steal my car, destroyed the ignition lock/switch in the process. Now I have hard time starting it.
Looked at the diagrams, wire #3 (as it sits at the plug, j/b) is not shown. As in here:
http://s483.photobucket.com/user/ColtRo ... l.jpg.html
Anybody knows the answer to this metaphysical question?
Got 1970 SS ?
PostPosted: Thu Jun 16, 2016 8:13 pm
I actually installed a push start switch in my '92 3g csm 1.5 non turbo, I'm not sure if the wiring would be the same, but the colors should be, if it is the black with red strip wire, that is your starter crank signal, if you were to put a pos+ power jumper to it, it should crank your engine.
I hope this helps if not let me know, like I said I recently did a push button start conversion, and when doing so I had to reverse engineering of all the wires that control the ignition switch, I made some wiring schematics, but pm me for those, I don't think it would be wise to post them on the INTERNET because the thieves pray on info like this, and I don't want to be the guy that leaks this info on to them :lol: .
Abe
