It is currently Tue Jun 04, 2024 8:00 am
 Post subject: Ecu Swap
PostPosted: Tue Mar 31, 2015 11:03 am
So I've got a 89 colt gt that's got an eeprom ecu that's socketed. Is there any reason I can't get a chip burned in this ecu for the injectors I want and a 2g maf and use it in my 90 gsx? As far as I know the two are pretty much the same. I'd be taking the stock ecu out and putting it in my colt as well.
 Post subject: Re: Ecu Swap
PostPosted: Tue Mar 31, 2015 1:28 pm
If you get the EPROM burned with all the code for a '90 GSX then it will work fine. The 1.6L stuff is a little different with regards to the fuel and timing tables. The ECU will plug right in and everything and work with all the '90 sensors though.
PostPosted: Tue Mar 31, 2015 1:51 pm
Sounds good so I should just specify to the guy burning the chip that it's for a dsm and all should be fine? Probabky have him load the 2g timing map on it anyways.
PostPosted: Tue Mar 31, 2015 3:56 pm
Tell him you want '90 GSX code in the ECU and then other specific things you want.
PostPosted: Tue Mar 31, 2015 7:48 pm
I would load whatever timing map will work with your motor/cams/MAF sensor setup. Your chip guy should be very familiar with this ... if not .... consider other options.
