http://www.4g61t.org/forum/
5th gear swap f5m33 into a f5m22??
http://www.4g61t.org/forum/viewtopic.php?f=6&t=38990
Page 1 of 1
Author:  waxie1 [ Wed Jul 16, 2014 5:50 am ]
Post subject:  5th gear swap f5m33 into a f5m22??
Hey all,
Does anyone know if the 5th gear from the awd f5m33 is interchangable with the f5m22 (km206) tranny? Really need to lower my RPM's.
Thanks,
Luke
Author:  thomcasey [ Wed Jul 16, 2014 6:50 am ]
Post subject:  Re: 5th gear swap f5m33 into a f5m22??
Doubt it would help much. What you want is the 5th gear out of a w5m33, these will lower them.
Author:  waxie1 [ Wed Jul 16, 2014 9:17 am ]
Ah thank you yes i mean w5m33. So to confirm it doesn't matter that it's a m22 not a m3X? The 5th gear can be swapped directly between a w5m22 and w5m33?
Author:  thomcasey [ Wed Jul 16, 2014 10:39 am ]
I haven't been able to find anything that states they are on different sized shafts
Author:  waxie1 [ Fri Jul 18, 2014 5:00 am ]
Spoke to a dude from jackstransmissions.com, he said "No unfortunately they don't interchange." :( What a bitch! I'm along your lines of thinking though, i'd like to see this for myself but not worth the outlay unless I can find a km210 at a wrecker. Thanks for investigating.
Author:  CaptainTonus [ Fri Jul 18, 2014 10:30 am ]
Yeah, you can't do it. The 5th gear is physically too large to fit in the case. You might be able to do it if you got the end cover from a F5M33 and put it on there, but that may not fit either.
Author:  89Mirageman [ Fri Jul 18, 2014 1:07 pm ]
I could be wrong but if a guy that worked on Mitsu transmissions on a regular basis told me it wouldn't work I'd take his word for it.
Author:  waxie1 [ Fri Jul 18, 2014 8:10 pm ]
Wishful pessimism but I agree MirageMan89. Thanks for the suggestion CaptainTonus. Think I might just try and find a whole KM210 gearbox if still possible here in Oz. Thanks all.
Author:  Natedog [ Fri Jul 18, 2014 9:26 pm ]
I know the km210 wont take an AWD DSM 5th gear, the gear is wider, will fit in the case, but the shift rail wont disengage it.
https://www.phpbb.com/
