It is currently Mon Oct 20, 2025 8:05 pm
PostPosted: Wed Jul 16, 2014 5:50 am
Hey all,
Does anyone know if the 5th gear from the awd f5m33 is interchangable with the f5m22 (km206) tranny? Really need to lower my RPM's.
Thanks,
Luke
90 4G63BT LANCER GSR Cyborg, 14b, KM206, Xtreme XHD Clutch
92 4G61 LANCER GSR
Speed Thrills, Hesitation Kills!!!
PostPosted: Wed Jul 16, 2014 6:50 am
Doubt it would help much. What you want is the 5th gear out of a w5m33, these will lower them.
PostPosted: Wed Jul 16, 2014 9:17 am
Ah thank you yes i mean w5m33. So to confirm it doesn't matter that it's a m22 not a m3X? The 5th gear can be swapped directly between a w5m22 and w5m33?
92 4G61 LANCER GSR
PostPosted: Wed Jul 16, 2014 10:39 am
I haven't been able to find anything that states they are on different sized shafts
PostPosted: Fri Jul 18, 2014 5:00 am
Spoke to a dude from jackstransmissions.com, he said "No unfortunately they don't interchange." :( What a bitch! I'm along your lines of thinking though, i'd like to see this for myself but not worth the outlay unless I can find a km210 at a wrecker. Thanks for investigating.
92 4G61 LANCER GSR
PostPosted: Fri Jul 18, 2014 10:30 am
Yeah, you can't do it. The 5th gear is physically too large to fit in the case. You might be able to do it if you got the end cover from a F5M33 and put it on there, but that may not fit either.
PostPosted: Fri Jul 18, 2014 1:07 pm
I could be wrong but if a guy that worked on Mitsu transmissions on a regular basis told me it wouldn't work I'd take his word for it.
PostPosted: Fri Jul 18, 2014 8:10 pm
Wishful pessimism but I agree MirageMan89. Thanks for the suggestion CaptainTonus. Think I might just try and find a whole KM210 gearbox if still possible here in Oz. Thanks all.
92 4G61 LANCER GSR
PostPosted: Fri Jul 18, 2014 9:26 pm
I know the km210 wont take an AWD DSM 5th gear, the gear is wider, will fit in the case, but the shift rail wont disengage it.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
