It is currently Mon Nov 03, 2025 6:47 pm
PostPosted: Wed Feb 06, 2013 8:57 pm
It's a 90 talon with a fresh Ecu, dsm link, rebuilt throttle body with all good associated sensors and I've tried two different transistors.
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Wed Feb 06, 2013 9:20 pm
PostPosted: Wed Feb 06, 2013 9:42 pm
No spark or no start?
PostPosted: Thu Feb 07, 2013 2:44 am
Car turning into a Decepticon [-o< ? [-o<
If so, I will trade you for a 2013 Kawasaki ninja or a Mazda Speed 3.
4g61t.com
PostPosted: Thu Feb 07, 2013 6:42 am
Hahaha. Video may help huh?
http://i155.photobucket.com/albums/s318 ... 378064.mp4
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Feb 07, 2013 7:24 am
Is it a 90 ECU? You will need to switch pins 6 and 14 if it is a 91+. Mine bounces a little bit too but not that bad. Tach filter maybe?
PostPosted: Thu Feb 07, 2013 8:03 am
The car is a 90 and has all 90 electronics. This is also its second coil pack too
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Feb 07, 2013 8:16 am
I believe the tach filter is separate from the 90 coil packs, It's on its own pig tail, did you check that?
PostPosted: Thu Feb 07, 2013 9:31 am
They are hard wired to the back of the coil if I remember correctly. I'd have to look up a pic
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Feb 07, 2013 1:28 pm
It looks like a small silver pill thing with 2 wires going to it, not far from the coil pack, bolted to the intake manifold iirc.
PostPosted: Thu Feb 07, 2013 2:27 pm
yes the 90 has the separate small silver tach box...
looks like this
http://img.photobucket.com/albums/v255/ ... 081402.jpg
PostPosted: Thu Feb 07, 2013 4:48 pm
Ill check that out. Thanks guys
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Feb 08, 2013 4:56 pm
I have a similar problem, swapped out that filter a few times, got a whole new coil pack, etc. Also bounces with the blinker, sometimes drops to zero, but kinda works better when I have the lights on. I'm probably going to take apart the light/blinker stalk, and clean the hell out of the contacts. You never know.
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Fri Feb 08, 2013 8:52 pm
I've also read that a bad alternator can cause this
2000 Lexus sc300
2016 ram 1500
