http://www.4g61t.org/forum/
riddle me this
http://www.4g61t.org/forum/viewtopic.php?f=6&t=34634
Page 1 of 1
Author:  twokss [ Mon Apr 25, 2011 4:43 pm ]
Post subject:  riddle me this
for all you 4gxx ladies and gentleman out there....how the f*** do you take the crank pulley off with the motor in the car? i have the new style crank bolt that requires a socket, not just a half inch breaker bar.
Author:  slowdsm [ Mon Apr 25, 2011 6:00 pm ]
Post subject:  Re: riddle me this
first you unbolt and remove the complete tranny mount so its out of the way...
second you remove the DS motor mount.. make sure u have a jack under the engine with a block of wood (so not to damage oil pan).
once engine mount is out.. lower the motor till u can get to the bolt.
Author:  93'TSIColt [ Wed Apr 27, 2011 1:53 am ]
on a colt, i dont screw with the front/back mounts at all.. just undo the timing belt side mount and then the 4 17mm long bolts that secure the lower crossmember to the unibody... put a jack under the crossmember or a block of wood under the oil pan and use a lack to lower it down enough for you to get the crank pully to clear the frame rail.
Author:  fastvtgsx [ Wed Apr 27, 2011 6:16 pm ]
Ya, definitely need to lower the motor to get it off with a 4g6X car.
Author:  93'TSIColt [ Wed Apr 27, 2011 11:16 pm ]
yeah luckily in dsm's you dont need to.. and my 4th gen colt it also comes off no problem.....
damn 3rd gens ahahah
Author:  Flying Eagle [ Thu Apr 28, 2011 5:35 am ]
While the motor is down to do the pulley removal, reorient the bolt holding the alternator so it comes out the opposite to the factory. Trust me when I say that the next time you have to change an alternator, you won't be dropping the motor down to do so.
Author:  twokss [ Thu Apr 28, 2011 6:22 am ]
Haha. Your about 2 weeks late on that one. I had to sawzaw the factory bolt off and go to the hardware store and find one close enough to match. Believe me I was pissed!!! Lol
https://www.phpbb.com/
