| 4g61t.org http://www.4g61t.org/forum/ | |
| an radiator hose fittings http://www.4g61t.org/forum/viewtopic.php?f=6&t=34554 | Page 1 of 1 |
| Author: | keith- [ Wed Apr 13, 2011 1:44 am ] |
| Post subject: | an radiator hose fittings |
| i want to use an hose and fittings for my radiator hoses what size are people useing to weld to there t stat housing and water pipe is it a -12 or -16 | |
| Author: | CSM Shaun [ Wed Apr 13, 2011 10:28 am ] |
| Post subject: | Re: an radiator hose fittings |
| Measure the internal diameter of the outlet of the thermostat in 1/16ths. The number in AN designations refers to how many 1/16ths the internal diameter of the fitting or hose is. So #6 AN is 3/8"(6/16") internal diameter or so on. | |
| Author: | biglady112 [ Wed Apr 13, 2011 11:31 am ] |
| I run -12 without issue. Most folks go -16 though. -12 will get it done, is cheaper and easily available to most local metro areas. | |
| Author: | keith- [ Wed Apr 13, 2011 11:59 am ] |
| thanks guys | |
| Author: | CrunchyMilk [ Wed Apr 13, 2011 8:16 pm ] |
| Depends on how you plan to use the car. I personally wouldn't run anything smaller than -16. I'm running -20 on my project. | |
| Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ | |
