It is currently Thu Oct 23, 2025 4:25 pm
 Post subject: engine mount problem
PostPosted: Thu Mar 03, 2011 10:50 pm
Since the car has been swapped from the 4g61t to a '63t, the front mount is pulled towards the pass side of the car. I've checked everything , tried reversing it, and filling it with window weld, and it just pulls back over. Anybody else deal with this issue?? :-?
 Post subject: Re: engine mount problem
PostPosted: Fri Mar 04, 2011 9:32 am
Which engine bracket did you use?
PostPosted: Fri Mar 04, 2011 9:48 pm
He has a stock 4g61t setup, c53a.
Have any mounts been changed or have you switched to a DSM FWD transmission?
When I swapped from the 4g61t to 4g63t, none of the mounts changed position. Strange ...
Wonder if you bracket on the block has twisted? I mean it is great if you are making more power, it just comes
to mind. With the picture you have there, it would appear that the bracket is twisted.
PostPosted: Fri Mar 04, 2011 10:07 pm
Hmmmm, this is a 4g61t from Japan that I snagged off Ebay - well the pic not the motor:
I vote bent. Sorry. But at least this way you are making enough power to bend things now!
PostPosted: Sat Mar 05, 2011 2:06 pm
Look at the top picture.. the mount is straight... now scroll up to the very top post in that pic the mount is bent..clear as day..simple solution new mount or large hammer lol
PostPosted: Sat Mar 05, 2011 2:36 pm
It does look like my mount is bent which came off the 61t, however if I straighten it, it won't line up with the crossmember :-?
PostPosted: Sat Mar 05, 2011 2:46 pm
Right now your bracket is intruding into the space the mount is supposed to occupy. It certainly will line up correctly once straight.
