It is currently Sat Nov 01, 2025 12:38 am
 Post subject: homie needs help
PostPosted: Mon Dec 27, 2010 7:27 pm
Ok i sprung a huge oil leak in the mist of fixing it i noticed the the previous owner just left the belt off the balance shaft is this another way to eliminate the bs that i have never heard of ? I have a spare case with a proper delete should i replace it and can i do it with the motor in the ca or leave it? I know the shaft is kind of long?
Help!!!!!
Str8fuct......
 Post subject: Re: homie needs help
PostPosted: Mon Dec 27, 2010 7:36 pm
The front one, the belt can just be left off. Some people leave it in, to not have to remove the bearings and such...
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Jan 04, 2011 11:43 pm
Yup... a lot easier to just leave the front shaft i then have to pound out the old bearings and install new ones. Plus is doesn't totally block off the oiling ports and allows some oil to still flow out the ports in the bearings... A common problem with BS delete is too high of oil press. after...
As long as he removed the rear balance shaft and replaced it with the stub shaft or machined it down to just a rod you will be mint.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
