It is currently Wed Oct 29, 2025 4:31 pm
 Post subject: ecm problem
PostPosted: Fri Dec 17, 2010 10:48 am
got a 89 colt gt ,,,,,well what ecm should be in there it still has the 61 in it ............. started looking and has a md192517 in it and it says 1,5 on the out side of it ,,,,,,,,,,is that the rite ecm lmk asap
 Post subject: Re: ecm problem
PostPosted: Fri Dec 17, 2010 10:55 am
While the cases are the same, dohc ecu's don't work, or fit, in sohc cars, and vice versa. The connectors are different for the wire harness. You either got a 1.5 motor, or they used a 1.5 case on the ecm. Also someone could have just wrote 1.5 on it.
4g61t.com
PostPosted: Fri Dec 17, 2010 11:04 am
ok here we go.got this car in a trade ......im not a dsm/CSM GUY i was a honda guy ......nuff said .... got this car and it has 3inch exthaust ,fmic,1g maf.....well it dont wont to idel and spits and sputters on low end...the guy i got it from had a safc on it and he took it off.....well after fixing the broken cts plug it still ran like shit .so i look at the ecm and theres a few wires left bare and un pluged from where the safc was removed . while i was looking i un bolted the ecm and found md192517 ..looked it up and thats a na ecm for a 1.5 ......so what now..any help would be great.lmk
PostPosted: Fri Dec 17, 2010 4:20 pm
Google the part number on the actual board. Not the case.
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Dec 17, 2010 8:43 pm
If there are wires that are obviously cut and not making a connection AND the car is not running right (I will also assume you have a CEL) then connect the wires!
What is your location? Maybe someone local can lend a hand. The Mods will probably tell you to add your location to your profile too!
PostPosted: Fri Dec 17, 2010 9:46 pm
http://www.4g61t.org/forum/viewtopic.php?f=2&t=9992
PostPosted: Sun Dec 19, 2010 8:45 pm
im in atlanta ga by the atlanta motor speedway
PostPosted: Mon Dec 20, 2010 9:23 pm
Buy a 90 eprom ecu. did you get the numbers off the board? any pictures of the car or ecu?
PostPosted: Wed Dec 22, 2010 6:29 pm
pulled the case and here is the number je331a979a
PostPosted: Wed Jan 05, 2011 1:56 am
when u have a safc abd then remove it, you have to make sure the MAFS wires are connected back together. If you remove it and dont reconnect the wires it will run like you say and throw codes left right and center.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Mon Jan 10, 2011 12:55 pm
Yep same problem I had. Installed ecmlink and just unplugged safc2 and it ran like hell. Reconnected and soldered wires and ran better than ever
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Wed Jan 26, 2011 4:48 pm
fix your electrical before you even think about plugging in an eprom ecu.
