If you have Expo knuckles then you can swap in GVr-4 hubs (if they aren't the same as Expo ones). Then you can fit regular Galant single piston calipers and rotors with 14" wheels. It would be a bolt on affair.
I would feel confident in assuming that the GVR4 hubs are identical to the Expo. Even if they aren't you don't need to swap the hubs to get the single pot calipers to fit. The Expo comes with single pot calipers all ready and they fit 14" wheels from the factory.
When I was at the yard pulling the knuckles, I checked the Expo calipers against a single pot DSM caliper and they look exactly the same - they bolt up to each other just fine.
I also pulled a set of twin piston caliper brackets and bolted them to the Expo hubs to take home. I just needed the brackets because I've had a set of the twin pot calipers I got a long time ago that didn't come with brackets.
If you ever get wheels bigger than 14" then you'll also be free to swap in twin pot calipers and 276mm rotors with ease.
That's the plan for my other Colt.
I'm going to pull another set of Expo knuckles on my next trip to the junkyard. I'll press out the Expo hub and replace them with DSM hubs. I'm sure they'll fit just fine but will have to confirm when I get around to it.
On another note, I picked up a Geo Metro Converible rotor today. My initial thoughts after measuring and test fitting some components are that I can probably make this work. Don't get me wrong - it's not a bolt on affair, but it's looking promising at this point.
I'll have some more info, progress, and pictures next time I post.
