http://www.4g61t.org/forum/
What are the right parts?
http://www.4g61t.org/forum/viewtopic.php?f=6&t=27143
Page 1 of 1
Author:  Christian421 [ Thu Dec 04, 2008 3:31 pm ]
Post subject:  What are the right parts?
Hi,
Engine is a 4G61 with some modifikations.
Follow parts are well installed:
cylinder-head, intake manifold(will change to a Cyclone-intake-manifold), throttel-body(60mm) and fuel-injektors(240's) of a 4G67. Air-mass-flow-meter is orginal, but with open big bypasses(this will no change). The fuel-pressure is available(regulator) and a SAFC-NEO is installed. A Data-logger is alltimes in this car. The ecu is a modifyed eprom 4G61 ECU. This will work on a Turbo-engine. A oil-cooler is well installed. Momently power is 135-140hp. I'm not shure... :lol:
This engine will goes turbo, with parts of a Mirage GT 1,6T.
The turbocharger:
I'm not shure if the orginal is an 11g or b or whatever. And i hope some of you can say me, what turbo-charger is the right to have after installation 160-170hp. I dont want over 200hp. The engine should dont go defekt... :lol:
The exhaust-manifold will be a 4G63T-part, this works much better on the 4G67-head, than a 4G61-part. What turbo is maby for me? And what is the orginal?
Shouldt i change the 240er Fuel-injektors(from a 4G67)? And how big have they to be?
The Fuel-pump is momently orginal. Some peoples in german forums think, this will work well. Does it?
A big thanks for awnsers.
Author:  Incoltnito [ Thu Dec 04, 2008 3:39 pm ]
Post subject:  Re: What are the right parts?
11b is the stock turbo on a 4g61t. You are going to need bigger injectors, like from a 4g63t...which are 450cc. The 4g67 injectors you have flow only 210cc's, and they will not be safe to use with a turbo.
For moderate power over the 11b turbo, you could upgrade to the 14b
Author:  Christian421 [ Thu Dec 04, 2008 4:01 pm ]
Hi,
the injektors of a german 4G67(136hp, 16V DOHC) are 240cc's. The 210cc-injektors, are stock on a 4G61(DOHC 16V 124hp). I dont think that anywhere is installed other injektors.
But i think the same. I need bigger injektors. :axe:
As turbo, at first i get a 11b. later i can get a bigger one, if its to powerless.
The fuelpressure is regulated at 4Bar's. Not 3.2Bar's like orginal.
Author:  Incoltnito [ Thu Dec 04, 2008 4:10 pm ]
Yes...it appears your injectors are 240cc. Definitely get some bigger injectors though.
https://www.phpbb.com/
