The problem as you say is the piston peeking above the hight of the bore, thats why im wondering if its the throw on the crank or the length of the con rods that make the diffrents?
You would have to run custom pistons with a shorter wrist pin, which would be expensive and make the project totally not worthwhile.
This is the same issue people run in to when they build stroker motors for DSM's. There is something like a 6mm difference in deck height between the
4G63 and the 4G64, so when people use the 4G64 crank in a
4G63 block they need custom pistons, or else the pistons will sit 6mm above the deck.
