It is currently Sun Nov 02, 2025 5:19 pm
 Post subject: Timming
PostPosted: Tue Dec 10, 2002 11:01 pm
Set the timing of the Colt today. Quick question
1) How does 8 deg. Advanced sound?
2) Do I match up the notch to the bottom or middle notch? It was greasy and hard to see.
Thanks
PostPosted: Wed Dec 11, 2002 9:06 pm
you should ground out the Yellow/red wire for correct timing.
PostPosted: Wed Dec 11, 2002 10:06 pm
WHat yellow/Black wire?!?!
PostPosted: Wed Dec 11, 2002 10:32 pm
Under the hood on the firewall pass side.
PostPosted: Thu Dec 12, 2002 2:20 pm
8 degrees isn't bad... 5 degrees is where its supposed to be stock. im adjusting mine today too. just replaced my CAS so i have to... my car finally runs though :) it should be near the middle notch
3" Mandrel Exhaust w/highflow cat w/Magnaflow. Apex'i AVC-R. TurboXs RFL BOV. Starion FMIC. Big 16g. 2g Manifold, O2 Housing, & TB eblow. Walbro 255. Homemade Poly motor mounts. MSD DIS4 Ignition. ACT 2600lb pressure plate w/street disc. K&N on custom cold air setup.
