It is currently Fri Oct 31, 2025 10:16 pm
PostPosted: Sun Dec 08, 2002 9:35 pm
well i finally went out and got the thing and when i took the car to the shop they stripped the old one while trying to get it out. now i have a dead o2 sensor stuck in my manifold, and they said that the only thing i can do is take the manifold, turbo, and o2 sensor housing off as one unit and maybe theyll be able to do it then. I'm thinking that while i ve got it off why not just buy a 2nd gen manifold and o2 housing and put that on, but will it fit all together if im still using a 11b, and will the 2nd gen o2 housing bolt up to my stock down pipe? this is becoming a night mare, my insurance is up soon and i cant pass the smog test without a new o2 sensor. thanks for any input guys.
Finally got my 4G61T.
PostPosted: Sun Dec 08, 2002 9:38 pm
BANNED FOR FRAUD
Truth is you will have a hell of a time just trying to wrench it out. You'll probably have to resort to removing it by all means neccesary. I can't get mine out so I'm using it as an excuse to get an Evo III sensor housing.
Jason Veraldi
Scammer
 Post subject: o2 housing
PostPosted: Mon Dec 09, 2002 12:40 am
do you know if the EVO III sensor housing will bolt up to a 11b and the stock exhaust down pipe, that would be an awesome upgrade, but whats the cost of the thing
 Post subject: O2 is no too easy...
PostPosted: Mon Dec 09, 2002 12:42 am
Ask Ricehunter how easy this is...even with the whole thing out and on a bench, he had to heat it till it was literally red hot around it to get the bloody thing out. That's what I get for going 138000 km without touching it. Copious amounts of anti-sieze were used that day, I assure you.
Member #533
1989 Colt GT (4G63 and a Lil 16G)Silver, 89Sonata tranny
1974 Fiat 124 Spider (Piece of S*it but I love it)
1995 Windstar (Wife's Child-bearer)
PostPosted: Mon Dec 09, 2002 1:27 am
haha, copious.
PostPosted: Mon Dec 09, 2002 7:08 am
the evo dump will not fit the 11b, its too big! even if youve got a 14b, the rest of the exhaust doesnt bolt up to the evo dump. Im running an evo2 dump on mine with a ported 14b housing.
I bought my o2 housing or dump pipe (as we aussies call it) for $60AUD
 Post subject: o2 sensor
PostPosted: Mon Dec 09, 2002 11:07 am
well if the EVO wont fit can i put a 2g housing on a 11b?" thanks
PostPosted: Tue Dec 10, 2002 6:57 am
unless the 2g is running a td04 it wont fit. The td04 and tdo5 dump pipe/o2 sensor housings are totally different sizes.
PostPosted: Tue Dec 10, 2002 1:53 pm
i had 140k miles on mine when i accidentally cut one of the wires :) when i went to replace it i had to put some good force on it, but no heat... just popped out.. guess i got lucky
3" Mandrel Exhaust w/highflow cat w/Magnaflow. Apex'i AVC-R. TurboXs RFL BOV. Starion FMIC. Big 16g. 2g Manifold, O2 Housing, & TB eblow. Walbro 255. Homemade Poly motor mounts. MSD DIS4 Ignition. ACT 2600lb pressure plate w/street disc. K&N on custom cold air setup.
PostPosted: Thu Dec 12, 2002 11:06 am
ok then will a 1st gen eclipse o2 housing fit onto the 11b? If none of this will work then i guess im gonna have to pull everything and just massage the dead one out , i was hoping i could just buy another housing. Thanks in advance.
PostPosted: Thu Dec 12, 2002 11:21 am
I think a 1G automatic one will fit. I'm not positive on that. Have you soaked it in penetrating oil? Let it soak and keep spraying it for a few days. Also, you can try to cut the wires and put a real socket on it, to try to break it loose. The o2 sensor socket will expand with a large amount of force on it.
