http://www.4g61t.org/forum/
Hears an Idea, getting wasted for cheap..
http://www.4g61t.org/forum/viewtopic.php?f=6&t=2514
Page 1 of 1
Author:  boostfreak [ Sun Dec 08, 2002 3:59 am ]
Post subject:  Hears an Idea, getting wasted for cheap..
Has anyone ever tried open atmosphere venting the wastegate on an internal wategate turbo, say a 16G? I was thinking of just having a flange made to bolt up to the turbo, Make it accept the O2 sensor, and having the wastegate port out of the fender to increase efficiency, limit boost creep, and scare V8 drivers, as if a turboed 4G63 in a colt isnt scary enough! What are everyones thoughts?
Author:  Guest [ Sun Dec 08, 2002 8:56 am ]
I've done this on my T25. Works awesome!
Author:  Ian [ Sun Dec 08, 2002 1:31 pm ]
im not seeing it that clearly... anyone have a diagram or a pic i can see? sounds like a reasonable idea though.
Author:  boostfreak [ Sun Dec 08, 2002 6:44 pm ]
Hey jmauld, how did you go about getting it done? Did you by a flange palne or have one custome made? How abou the pipeing? And how much did it run of rya? Any and all details would be helpfull, thanks
Author:  Guest [ Sun Dec 08, 2002 7:36 pm ]
A friend of mine built it. He used flanges and a 2.5" Stainless Steel donut pipe that he got from RRE. I think it was about $30-40 in parts.
I have some pictures somewhere. When I find them, I will put them on here.
Author:  Broke4speed [ Sun Dec 08, 2002 8:37 pm ]
My roomate has done this exact thing on his AWD Talon...sounds hella mean when he hits max boost :). Scare the heck out of you if you are not ready for it....
Author:  92colt200e [ Mon Dec 09, 2002 11:17 am ]
Sounds interesting, we def needs some pics, I had my bov vented to the atmosphere this past summer, was loud when boost was reached, but at idle she ran like a bag of shit. :-(
Author:  Ricehunter [ Mon Dec 09, 2002 11:41 am ]
All you need to do is cut the wastegate dump at the return and weld a patch over the retun hole. You would cut the area out that's marked in red.
For thos of you interested Fatbastard has one modified that's most likely for sale.
Author:  boostfreak [ Mon Dec 09, 2002 3:43 pm ]
On a stock O2 housting?! So then it would be dumping right onto the radiator?! I dount like the sould of that. Is their any way to run a pipe wiht this Idea? I got one.. Can anyone think of a shop in their area that could mass produce this? This would be a ig money maker, seeing as it will work for most of the mistu turbo lineup.
Author:  Broke4speed [ Mon Dec 09, 2002 4:29 pm ]
Sure, you just weld an outlet pipe onto the housing. You can have it vent anywhere you want it to, I'm going to have mine blasting pavement :).
Author:  phntmenace [ Mon Dec 09, 2002 4:33 pm ]
here's a copy of a pretty one.....
You can do it to a stock o2....
I have one if you're interested..... Give me 90.00 bucks and it's yours.
Geoff
Author:  cyborg_89 [ Mon Dec 09, 2002 7:31 pm ]
Check out this link for complete instructions on how to build one.
http://www.geocities.com/spencerhut/talon/down_pipe.htm
Author:  boostfreak [ Mon Dec 09, 2002 9:45 pm ]
http://www.forcedperformance.net/images ... ped_o2.jpg
Here is a stoch one with the dump mod. Looks like fun
https://www.phpbb.com/
