It is currently Thu Oct 30, 2025 9:40 pm
PostPosted: Mon Dec 09, 2002 2:47 am
These wheels I am looking at getting for the mirage I believe are the correct bolt pattern: 4x114.3 (confirm this?). and they are 15X7 with a +32 offset. Can anyone tell me that these will be fine or have fitment issues, I'm not really worried about the hub bolts, I figure if those are a problem, I will grind divets in the back of the rim.
www.freewebs.com/locost
PostPosted: Tue Dec 10, 2002 3:28 am
BANNED FOR FRAUD
A 32mm offset will definately not work. You'd need wheel spacers. The factory offset it 46mm. The lowest you can go I believe is 42mm.
Jason Veraldi
Scammer
