It is currently Sun Nov 02, 2025 4:34 am
 Post subject: compression question
PostPosted: Sun Apr 01, 2007 10:34 pm
I am currently building a NA 4G63 with 2g turbo pistons and I need a head for this engine. I am going to the pull apart to get another head and I'm wondering if I get one from a 1.8 Elantra if it'll boost the compression up too much for turbo use? Or should I get a 2.0 DSM head? Can anyone tell me what the C/R will be with the 1.8 head?
This engine is going to be a stock rebuild with a 14b and 450's. I am going to eliminate the balance shafts also. It's basicly going to be a decently quick car that is stock and reliable with ac and all the goodies, not a race car.
PostPosted: Sun Apr 01, 2007 11:35 pm
i'm not possitive. but i think the heads are the same and the difference is in how tall the block is...i could be wrong though :ANAL:
PostPosted: Mon Apr 02, 2007 1:40 am
Chris, I would use a 4g63 head on it since you will already have an 8.5:1 motor with the 2g pistons.
PostPosted: Mon Apr 02, 2007 10:13 am
That's what I was thinking. Turbo and non turbo heads are identical, correct? The cams are the only difference?
PostPosted: Mon Apr 02, 2007 10:14 am
Yessir.
PostPosted: Mon Apr 02, 2007 11:31 am
With the 4g67 Head your CR would raise to 9.5:1 which is not the best.Even the Evo3 had Issues with 9.1:1 in stock Trim.
Lancer C68 4G67t
Eclipse D22 4G63 Cyclone
Eclipse D27 E316g,too much to List here.
Galant EA0 V6-24V
PostPosted: Mon Apr 02, 2007 12:32 pm
Turbo heads have the hole drilled at the front for the oil pressure to feed the turbo - stock. Not an issue if you can drill tap/or run a turbo that can feed from the oil filter location.
PostPosted: Mon Apr 02, 2007 3:30 pm
I dont know if there is a difference in EUDM and USDM Parts,but our EUDM NA Heads have the Hole drilled too.
Lancer C68 4G67t
Galant EA0 V6-24V
PostPosted: Mon Apr 02, 2007 3:54 pm
I dont know if this is a difference in EUDM and USDM Parts,but our EUDM NA Heads have the Hole drilled too.
confirmed.
im sporting the 4g67 (1.8 ) n/a head (JDM) that comes with the drilled hole standard. there's a lil bolt plug that replaces the turbo banjo bolt.
this is the same on my 4g61 n/a and 4g63 n/a heads i have laying about.
i think all the heads are identical in design/casting. only the port sizes and of course cams/profiles made the difference.
96 Lancer Stationwagon - 4G61T swap (rebuilt) (4g67 head, 4g63 intake mani), 390cc's, ported exhaust mani/with 2.5" custom d/pipe, TD04-13g (ported), Greddy Emanage (Gold Edition), VR4 18x12x3 IC with custom piping/hose, SR-20 (Silvia) Recirc BOV, Walbro 255lph pump, custom 2.25" press bent de-cat exhaust, ACT 2100 (4g67 g/box), front EVO II brake/booster upgrade
PostPosted: Mon Apr 02, 2007 5:26 pm
Thanks! Is this hard to figure out or can you explain how you figured it out? What would the compression on an engine with 1g pistons have with the 4G67 head?
PostPosted: Tue Apr 03, 2007 12:42 am
Thats easy.If you swap either a 4g67 on a 4g63,or the other way,a 4g63 on a 4g67 its either exactly +1 CR or -1 CR.
Your CR is 8.5:1 caused by the 2g Pistons +1 by the 4g67 Head.With the 1g Pistons you get 8.8:1
Lancer C68 4G67t
Galant EA0 V6-24V
