| Leaking oil......Help..... http://www.4g61t.org/forum/viewtopic.php?f=6&t=20742 |
| Author: | Evo-Jr [ Fri Mar 16, 2007 5:57 am ] |
| Post subject: | Leaking oil......Help..... |
What up.. I bought a build motor from a friend of my, the balance shaft has been removed. After starting the car for the first time is leaking oil from the balance shaft.... Anybody know what when wrong or if i need to replaced anything... Thanks.. |
| Author: | 2.0pwrdc50 [ Fri Mar 16, 2007 6:30 am ] |
| Post subject: | |
did you plug that old hole in the front cover? where the shaft was. also need to put a bolt in the hole where the old pulley was. http://www.vfaq.com/mods/balance-shafts.html |
| Author: | pttcolt [ Sat Mar 17, 2007 5:21 pm ] |
| Post subject: | |
Make sure the the plug for the front balance shaft didn't pop out. They do that sometimes |
| Author: | Evo-Jr [ Tue Mar 20, 2007 6:10 am ] |
| Post subject: | |
what plug? The bolt is where the balance shaft was removed, im going to put sylicon to see if stop leaking. Thanks.... |
| Author: | pttcolt [ Wed Mar 21, 2007 4:56 am ] |
| Post subject: | |
Quote: what plug? The bolt is where the balance shaft was removed, im going to put sylicon to see if stop leaking. Thanks....
The plug goes here
| Author: | Evo-Jr [ Wed Mar 21, 2007 6:10 am ] |
| Post subject: | |
Quote: Quote: what plug? The bolt is where the balance shaft was removed, im going to put sylicon to see if stop leaking. Thanks....
The plug goes here ![]() |
| Author: | 2.0pwrdc50 [ Wed Mar 21, 2007 6:13 am ] |
| Post subject: | |
i answered your question with my first post. mayb you just didnt understand it.
| Author: | pttcolt [ Thu Mar 22, 2007 3:25 am ] |
| Post subject: | |
No problem man. |
| Author: | Evo-Jr [ Sat Mar 24, 2007 2:17 pm ] |
| Post subject: | |
No hard feeling. U answer my question too and also give that webside to look at. I really thank you.....
