http://www.4g61t.org/forum/
cylinder head removal
http://www.4g61t.org/forum/viewtopic.php?f=6&t=19980
Page 1 of 1
Author:  quikgt [ Wed Jan 10, 2007 12:26 am ]
Post subject:  cylinder head removal
what size tool to take off the head studs?
Author:  colt200 [ Wed Jan 10, 2007 12:37 am ]
If take it your talking about the factory heads studs? If so, not sure, 50 or 55 maybe allen wrench. Can get it in a socket, I suggest a 1/2'' drive as I broke my 3/8 one (good thing it had life time warranty).
If you are talking about ARP's I think the nuts are a 12 point 10 mm.
Author:  SpinMasta11 [ Wed Jan 10, 2007 1:07 am ]
10mm allen socket
Author:  customthecoltgt [ Wed Jan 10, 2007 1:28 am ]
10mm allen socket
look not 10mm is the key I have like 4 i don't know why.
Author:  Mechacode [ Wed Jan 10, 2007 4:07 pm ]
English?
Yeah, it's 10mm. I just did it so I'm 100% sure.
Author:  MR HYDE [ Wed Jan 10, 2007 5:31 pm ]
Yes, you'll need a 10mm allen socket preferrably with a breaker bar.
Author:  89coltgt [ Thu Jan 11, 2007 2:42 am ]
Yes, breaker bar definately helps. When/if you do pull the head, be sure that the hex part of the bolt are clean and not full of crud that way you get maximum "bite" with the allen socket. I have stripped out a bolt on a 4g63 before and I believe this may have caused it. We ended up cutting the head of the bolt off with a torch after numerous times welding a soket to the bolt-needless to say, the head was trashed :-?
Author:  quikgt [ Thu Jan 11, 2007 9:00 am ]
Thanx for the replys :)
Author:  Goat_Boy [ Thu Jan 11, 2007 7:44 pm ]
I usually just cut a ~2'' piece off of a standard allen wrench and put a socket over it.
https://www.phpbb.com/
